23844 Discussions
Intel Graphics Command Center can not detect internal display
minhnq12
Hi today I reinstall Windows 11. After update all drivers and install Intel Graphics Command Center latest version 1.100.5237.0, I can not adjust any settings on Display tab. I installed Windows 11 22H2, 23H2 but this bug still exist. Previous version 1.100.5185.0 work fine. I'm using Acer laptop Nitro 5 AN515-57. I hope this bug can be fix soon.
Hugo_Intel
Hello minhnq12
Thank you for posting on the Intel Communities.
Most of the settings from the display tab were migrated to our newer Intel Arc Control Software we would advise that you use the Intel® Graphics Command Center (BETA) version available in the Microsoft Store in case you still need the display settings. Check the following article for more information:
The Resolution Setting Option Is Missing in the Intel® Graphics Command Center (IGCC)
Intel® Graphics Command Center Missing Capture & Game Related Features
Hugo O.
Hugo_Intel
Hello minhnq12
Hugo O.
minhnq12
Hi Hugo O,
Thanks for your fast reply. I installed Intel Arc Control and now I can adjust settings on Display tab.
Hugo_Intel
Hello minhnq12
Good to know the information helped. I do believe as well that using Arc Control is the best option since it will continue to receive regular updates and other settings will be added as well. We will now close this thread since it is resolved. feel free to ope a new topic if you need further assistance.
Hugo O.
