22828 Discussions
Asus ProArt Thunderbolt Monitor Stuck at 30Hz and 8-bit color
5urg3
Host computer is:
HP Z2 Mini G9 with HP Thunderbolt 3 FlexIO module
Operating System: Microsoft Windows 11 Professional (x64) Build 22631.2715 (23H2)
BIOS 8/31/2023
Monitor is:
Asus Pa32UCX
This monitor works perfectly fine with a M1 Mac Mini, 60Hz and 10-bit color
When using it with the same thunderbolt cable with this HP computer, it's limited to 8-bit color and 30 Hz 😞
Please help!
Current CPU is i5-12500
Jose_Intel
Hello @5urg3
Thank you for posting on the Intel️® communities.
We understand you are experiencing some issues with Intel® UHD Graphics 770, we will be more than happy to provide you with some information.
After checking the compatibility of your HP Thunderbolt 3.0 Flex IO, we found that your computer is not listed there.
Also, according to the HP Z2 Mini G9 Workstation User guide on page 16, it says: Monitors with resolutions above 1920 × 1200 pixels at 60 Hz require a graphics card with either Dual Link DVI (DL-DVI) or DisplayPort output. To get native resolution with DVI, you must use a DL-DVI cable, not standard DVI-I or DVI-D cables.
We highly recommend contacting HP Computer Support for further assistance.
If your computer was able to display that resolution before, using the same monitor, cable and converter, please let us know.
Jose B.
5urg3
I rebooted a few times and now it works, though I now have another problem — I can only enable 10-bit color with HDR turned on. I should be able to use 10-bit color with SDR as well. But it seems I can not, for some reason. I’ve already got a separate case with Intel about this, waiting for a response.
There is something very screwy with this thunderbolt module though…HP support are useless but I’ll try opening up a case with them.
Jose_Intel
Hello 5urg3
Thank you for your reply.
We are glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior.
Since the thread is now solved, we will proceed to close it. You will be helped through the chat channel about your new case.
Jose B.
