23734 Discussions
Intel Graphics Control Panel crashes
KFury1
My HD Control panel crashes every time I try to open Help in it.
My issue is quite similar to /thread/54034?q=INtel%20Graphics%20Control%20panel%20crash this and /thread/64793 that, but none of the above solutions helped. What I've tried:
  1. Full reinstall of driver with the removing of any leftovers.
  2. Removing GfxUIEx.exe.config file (wasn't found)
  3. del igfx*.*
Video Adapter - Intel HD Graphics 530
Installed driver: https://downloadcenter.intel.com/download/26404/Intel-Graphics-Driver-15-45-?product=88345 15.45.10.454 (latest)
Stefan3D
"Welcome to the club"
Although your call stack doesn't expose screwed .NET runtimes check out:
KFury1
My digit grouping symbol is already set to comma
Stefan3D
There seems to be sth. wrong with MS' problem logger?
Gfxv4_0.exe has no dependencies at all, but igfxCPL.cpl loads oleaut32.dll according to http://www.dependencywalker.com/ Dependency Walker
Go to the listed app path above, start Gfxv4_0.exe and igfxCPL.cpl manually to see if it makes a difference.
KFury1
No difference. Manual launching of the above two files gives the same crashing.
This issue is still under investigation, hopefully it will be fixed soon, but I cannot guarantee it.
Best wishes,
Ivan.
KFury1
Still waiting reply about this issue, which can be connected to /message/441724 this one.
MHans14
I have the same crashing problem.
I also have flickering task bar since W10 upgrade.
Please check the following link and see if this is the same issue:
https://communities.intel.com/thread/98556 https://communities.intel.com/thread/98556
If it is the same there is already a fix for this issue. This is currently being retested and our goal is to incorporate it in our next driver updates.
Ivan.
