23850 Discussions
Intel Graphics Software 32.0.101.7077
Compuwin
HP Elitebook 830 G8 Notebook PC keeps freezing everytime i install the:
JeanetteC_Intel
Hello Compuwin,
To properly isolate the problem and provide an effective solution, I need to gather some additional information:
  1. When did this freezing issue first start occurring?
  2. What changes were made to your system prior to experiencing this problem?
  3. Were you experiencing any graphics issues before installing driver 32.0.101.7077?
  4. Where did you download this driver from? (Intel's website, HP Support, Windows Update, etc.)
  5. What graphics driver version were you using previously?
  6. What troubleshooting steps have you already tried?
  7. Are you able to boot into Safe Mode after the freeze occurs?
  8. Have you attempted to roll back to the previous driver version?
  9. Please run Intel System Support Utility (SSU) and share the log file - this will help us analyze your system configuration for any contributing factors.
This information will help us identify the root cause and provide the most appropriate resolution.
JeanetteC.
JeanetteC_Intel
Hello Compuwin,
Let us know if you have any questions.
JeanetteC.
Compuwin
Dear JeanetteC
I am busy doing a final test, and then I will send the Info requested to you.
Look like there is a behaviour change when I connect an external screen via a C-type USB to HDMI converter, instead of directly to the laptop's HDMI port. Then the drivers work 100% fine; and the Laptop dont freeze; but the moment I plug out the external screen, the laptop freeze
Kind Regard
JeanetteC_Intel
Hello Compuwin,
Thank you for sharing this update. It's interesting that the system behaves differently depending on the connection method (USB-C converter vs. direct HDMI). This detail about the laptop freezing specifically when disconnecting the external display will be crucial for our analysis.
I'll wait to receive the details I mentioned previously. Please share them whenever it's convenient for you, and we'll proceed with further analysis once I have that information.
JeanetteC.
Vaish1
I’m experiencing the same issue on my Dell G15 5520. With Intel Graphics Software version 32.0.101.7077, my system sometimes shows a black screen or screen flickering. This can happen even when the system is idle or just on the desktop, not only during heavy tasks. However, my screen doesn’t freeze, it only flickers.
Please help
Kind Regard
JeanetteC_Intel
Hello Compuwin,
Good day!
I wanted to check in regarding the freezing issue you're experiencing. I previously requested some additional information to help troubleshoot your problem effectively. Once I have those details, I'll be able to provide targeted solutions for your specific situation.
Looking forward to hearing from you soon.
JeanetteC.
JeanetteC_Intel
Hello Compuwin,
As I haven't heard back from you recently, I'll proceed to close this thread.
If you require additional support moving forward, please feel free to create a new ticket since this thread will no longer be monitored for responses.
Sincerely,
JeanetteC.
bb31
bonjour, j ai le meme soucis : l ecran devient noir avec le pilote 32.0.101.7077 et le pilote 32.0.101.7084.
l'affichage est bon quand je désactive la carte Intel UHD graphics, bon en mode sans echec et aussi bon avec un USB3.0graphic card HDMI 4k adaptater. l'ordinateur est un HPelitebook 650 g9 i7-12550.
en attente de votre aide
cordialement
B Bachelot
