23819 Discussions
Intel HD 2500 Sound
Gaviebaby
I have a i5 3570 with a intel hd 2500 video card and when i plug in my dp cord to use my intel video the video and sound works till i change my resolution then my sound cuts out but my video still works, i am using a dp to hdmi converter
anyone else have this problem or have any solutions
n_scott_pearson
We can't do any kind of analysis with the scant information that you have provided. What specific display(s) are you connecting? How physically are you connecting them? Which DP-to-HDMI converter are you using? Have you checked to see if there is a firmware update available for this converter? [even if it's a cable, there may be updates]
Gaviebaby
im connecting  my pc to a konica 42" tv using a 4k ultra hd generic dp to hdmi converter which is about the size of a memory stick with no brands or number on it
Gaviebaby
n_scott_pearson
So, you start off at standard 4K@60Hz. You then change the resolution to ???
Gaviebaby
the display and sound work till i change any settings, res , resfresh rate etc
Gaviebaby
The Specs Of The Pc Are
Dell OptiPlex 9010
CPU: Intel Core i5-3570
MB: DELL 0KV62T, Intel Q77 (Panther Point DO)
GPU: Intel HD Graphics 2500
RAM: x2 4GB DDR3 12800, X2 8GB DDR3 12800 =24gb over killi know
Windows 10 Pro 22H2
n_scott_pearson
What is the specific change that you make?
