23843 Discussions
Intel HD 3000
BSwit
I am working with a police department that are using four Lenovo Edge E430 Think PAD laptops paired with four Logitech C920 web cameras as dash cams in the vehicles. One for each car. I have noticed in each car (laptop) that the video freezes after 30 to 60 seconds. The specification on the laptops are as follows:
Intel i5-2450M CPU @ 2.50 GHz
6 GB RAM
Windows 7 64 bit OS
This application seems to work on most all laptops but this particular model laptop using the Intel HD 3000 graphic card seems to have trouble decoding the H.264 video from the Logitech C920 camera. I upgraded the on the Lenovo as well as the Lenovo graphic card driver but still the video freezing issues occurs every 30 seconds when their is movement in the background scene.
I know this must be something simple but I am at a loss. If I can figure out how to correct the issue then I could get all 4 cars up and running.
Please help.
Jose_H_Intel1
Hello coptrax, please share more information with us:
  • The name of the software being used with the cameras, is it the one provided with the cameras?
  • The Intel® HD Graphics report. This article will guide you: http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics; Intel� Graphics Driver Report. Please indicate the driver versions used if more than one.
  • The Dxdiag report. Please type "dxdiag" in the search box or in "Run". Then, click "Save all information..."
This is the latest generic Intel® HD Graphics 3000 driver version: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23377 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23377
BSwit
System Information
Time of this report: 12/20/2013, 13:19:27
Machine name: MFOWLER-CAR29
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: 3254AEU
BIOS: Phoenix BIOS SC-T v2.2
Processor: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz (4 CPUs), ~2.5GHz
Memory: 6144MB RAM
Available OS Memory: 5734MB RAM
Page File: 1948MB used, 9516MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 3000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_500017AA&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: ThinkPad Display 1366x768
Monitor Model: unknown
Monitor Id: LEN40A0
Native Mode: 1366 x 768(p) (59.996Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.3347 (English)
Driver Version: 9.17.10.3347
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 11/7/2013 01:52:50, 12617216 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4266-11CF-0979-0A70B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0126
SubSys ID: 0x500017AA
Revision ID: 0x0009
Driver Strong Name: oem13.inf:Intel.Mfg.NTamd64:iSNBM0:9.17.10.3347:pci\ven_8086&dev_0126
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
BSwit
The software we are using is AMCAP (a DirectShow Product)
The version of the driver is 9.17.10.3347
BSwit
I have attached the DXDiag as well as driver info.
BSwit
Was any of the information that I sent helpful?
Jose_H_Intel1
We are checking on this. Thanks!
Jose_H_Intel1
Would you please attach the Intel® HD Graphics report? This article will lead you to it: http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics; Intel� Graphics Driver Report.
BSwit
I have attached the Intel HD Graphics report.
Jose_H_Intel1
Thank you, I have some questions:
Is the live footage or the saved footage choppy?
What software are you using for viewing/playback?
BSwit
The live video hangs up as well as the recorded video. It seems like it the video card is unable to "keep up" when the background scenery starts moving fast. We are using the Direct Show AMCAP software program to record the video.
Jose_H_Intel1
Did you test with different software? Perhaps the one provided by the webcam's manufacturer?
Jose_H_Intel1
Please take a look here: http://forums.logitech.com/t5/Webcams/C920-Webcam-jerky-framerate-on-Windows-8-64-bit/td-p/1124365 C920 Webcam 'jerky' framerate on Windows 8 64-bit - Logitech Forums
