23050 Discussions
Intel HD 4000 after update the driver
hi
After i updated the newest HD 4000 driver , it seems it was getting more worse than the basic driver.
I have played league of legends and the fps keep droping all the time and not stable after update the newest driver .
Also , as i know the newest driver is fixed league of legends about the screen problem , but i have go in the game and check it and the problem still in here.
please contract me if you have any information about this
Regard
DArce
Valued Contributor III
Could you please copy-paste the graphics report generated within the Intel® Graphics User Interface. For information on how to retrieve this report, please visit the following page:
http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
i have down grade to 9.17.10.2867 now...because 9.17.10.2875 is not stable.
Intel(R) HD Graphics 4000
Report Date: 12/30/2012
Report Time[hh:mm:ss]: 11:20:04
Driver Version: 9.17.10.2867
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: Chinese (Traditional, Hong Kong S.A.R.)
DirectX* Version: 11.0
Physical Memory: 7877 MB
Minimum Graphics Memory: 256 MB
Maximum Graphics Memory: 1760 MB
Graphics Memory in Use: 186 MB
Processor: Intel64 Family 6 Model 58 Stepping 9
Processor Speed: 3400 MHz
Vendor ID: 8086
Device ID: 0162
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 2132.0
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Digital Displays: 1
* Digital Display *
Monitor Name: 一般 PnP 監視器
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 20.08 inches
Vertical: 11.42 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
800 by 600 (60 Hz)
1024 by 768 (60 Hz)
1152 by 864 (60 Hz)
1280 by 960 (60 Hz)
1280 by 1024 (60 Hz)
1680 by 1050 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 1E 6D 0C 58 7C C5 04 00
05 15 01 03 80 33 1D 78 EA 32 65 A2 55 4D A0 26
11 50 54 21 08 00 71 40 81 80 81 40 B3 00 01 01
01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 FE 22 11 00 00 1E 00 00 00 FD 00 38 4B 1E
53 0F 00 0A 20 20 20 20 20 20 00 00 00 FC 00 49
50 53 32 33 36 20 20 20 20 20 20 20 00 00 00 FF
00 31 30 35 4E 44 45 5A 39 36 37 30 30 0A 00 D0
* Other names and brands are the property of their respective owners. *
i have already setup the new driver
about the video issue persists !
i would like to tell more about information about the video issue. One of the HD4000 User said that if you watch a youtube in the LOL , when you switch 240p it was fine, if you switch to 360p/480/720 ,it can not show out anything just like the # 1 post that picture.
It seems the fps problem it is better than 9.17.10.2867 and more stable . Because my game setting i set the config is everything to be LOW*
Please contract me if you have any new information about the driver !
regard
