22923 Discussions
Intel HD 4000 freezes my computer
I have Windows 8 and Intel HD 4000 graphics. The driver version is 9.17.10.2867. When I try to play a game in full screen it freezes my whole computer. Does anyone else have this problem? And is there a way to fix it?
I have the same problem. The lock-up occurs when playing most 3D games.
My system:
Win7 64 and Win 8 64
Shuttle SZ68R5 with latest BIOS 2.03
I7 3770
Trenscand DDR3 1333 8Gx4
Integrated HD 4000
Different driver versions are tested including the latest version 9.17.10.2875, the lock-up always happens in few minutes after launching any 3D game either in window mode or full-screen mode.
However, the issue seems to go away if only one memory module is installed (game runs for hours).
On the contrary, It is much easier to trigger the lock-up with 4 dimm slots populated (game and system freeze in few minutes).
All the memory modules pass the Mem86+ test and OCCT linpack (90% mem usage) test.
So it is not a faulty memory problem.
Hello
I've got the same problem.
New build
I5 3570k
ASUS P8Z77-V LX
2x4GB 1600
PSU Corsair 600W
win 7 64
I've updated Bios and all drivers and all games are freezing when using Intel HD Graphics 4000.
Also tested with external graphic card and it works like a charm.
Any updates on that.
Waiting for response
Fixed! Bios 1709 was just release for my P8Z77-V Deluxe mobo and it fixed the freeze issue with the new intel driver. Can play Call of Duty Black Ops 2 now!
FYI my system: Asus P8Z77-V Deluxe, i7 3770K, 16GB G.Skill @2133, 256GB SSD Samsung S830
Btw, does anyone know why Asus never adds detailed release notes for a bios update? Or do they? Not at the download page for sure.
Thijs
Fixed! Bios 1709 was just release for my P8Z77-V Deluxe mobo and it fixed the freeze issue with the new intel driver. Can play Call of Duty Black Ops 2 now! /tags/# /?tags=cod:bo2 cod:bo2
Thijs
Great news guys. It's nice to finally have a stable system isn't it. I'm not sure where you can find bios release notes. All it mentioned for the 1408 maximus bios was support for new processors and system stability improvements.
Happy gaming
Asus P8Z77-V lx, i5 3570K, 2*4GB Samsung 1333,
Win 7 pro 64, driver versions 9.17.10.2875, BIOS 1404, Freeze happens in few second after launching any 3D full-screen mode (game, benchmark). Also freezes at BD3D in full-screen mode (CyberLink PowerDVD 12+ OPTOMA HD33).
Hi Andrey, I'm betting that it is likely still your bios that needs updating. Your current bios, 1404, was released just over three weeks ago. Most of us asus mobo owners have seen our problems fixed with bios versions that have been released in the last five days or so. Sit tight man and hopefully an updated one will turn up for your motherboard.
Everything works yet don't touch memory settings. As soon as you change frequency of memory from "Auto" (even if thus frequency doesn't change) FREEZE comes!!! Return to "Auto" doesn't help.
I have updated intel graphics driver and bios, still system freezes when any game is started
or while running PassMark 3D graphics test
Asus P8Z77-V lx
i7 3770K
2 X 4GB Corsair 1600 MHz (CMZ8GX3M2A1600C9G)
Windows 7 64 bit
Intel graphics driver version 9.17.10.2875
BIOS 1404
Hi Abhijit
1) Dump the BIOS settings by CLRTC jumper.
2) Reupdate BIOS 1404 through EZ Flash 2.
3) Redump the BIOS settings by CLRTC jumper.
5) If it is required, change "DRAM Voltage".
6) Check problem existence... if all ok, save "ASUS O.C. Profile" and go further...
7) Configure the BIOS settings (WITHOUT TOUCHING "memory frequency").
6)Check problem existence... If ok, save profile...
😎 Try to change "memory frequency".
9) Check problem existence... if have it, load the kept profile.
Write ASUS and we wait new BIOS...
Thanks Andrey,
I have cleared BIOS settings(CLRTC) and re-installed BIOS 1404 using EZ Flash 2.
Graphics seems to be working (tested a game for few minutes).
PassMark is able to complete 3D graphics test.
Hi Abhijit
Change "memory frequency" leads to stability loss?
Freeze issue was resolved with reset and re-install of BIOS 1404 however issue came back when system was restarted(auto tuning of settings).
Clearing settings again and re-install of BIOS fixed it.
I haven't changed memory settings. Not able to figure out correct manual settings.
entilza
Andrey! You Sir are a Genious, Thank You!
I just built a P8Z77-V LK and was trying Kinston 1600 memory (KHX1600C9D3K2) which required to increase the voltage to 1.65. After reading that perhaps it may be dangerous to run other than 1.5V I switched it back to 1.5 and auto.
I had the latest BIOS 0904 installed as well as of Nov 24, 2012.
The system was running fine until I decided to test the 3D capabilities of the HD4000 chip.
After running unigine it crashed immediately when the dragon was at around 15% loaded. Each time a complete system freeze. Quite shocking actually. I was quite concerned but after reading your post and knowing I had previously played with the memory speed I thought maybe it was related. I just reflashed the bios again with the same lastest one and this time touched nothing and it worked perfectly.
So thanks again, and hopefully your post will help intel/asus whomever resolve what is causing it to crash so badly.
I am not able to change DRAM frequency or voltage.
I changed settings to manual and updated frequency and voltage. It resets after system is restarted.
Even after cancel of OC Tuner it updates automatically.
Please assist.
VNeme
Same here, though reading through the previous posts I'll need to wait for a BIOS update - P8Z77-V LX...+3570K
+, P8Z77-V LX, 3570K all up to date.
Maybe power plan some way affecting.
Performance and balance - instant freeze.
Power saver - freezes seems rare
dxdiag, if need.
System Information
Time of this report: 12/2/2012, 10:40:11
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 10/12/12 09:53:37 Ver: 14.04
Processor: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz (4 CPUs), ~3.4GHz
Memory: 16384MB RAM
Available OS Memory: 16076MB RAM
Page File: 2791MB used, 14083MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0162&SUBSYS_84CA1043&REV_09
Display Memory: 1760 MB
Dedicated Memory: 256 MB
Shared Memory: 1504 MB
Current Mode: 1360 x 768 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: LG TV
Monitor Id: GSM0001
Native Mode: 1360 x 768(p) (60.015Hz)
Output Type: HDMI
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2875 (English)
Driver Version: 9.17.10.2875
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 10/22/2012 17:40:22, 12615168 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4222-11CF-C878-C0A4B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0162
SubSys ID: 0x84CA1043
Revision ID: 0x0009
Driver Strong Name: oem9.inf:Intel.Mfg.NTamd64:iIVBD0:9.17.10.2875:pci\ven_8086&dev_0162
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering...
VNeme
Actually, try the following.
Boot computer into Windows. Open AI Suite II. Set GPU to anything other than the default (I set it to 1450). Play.
It seems to work, but has to be re-done on each boot. (You also might need the old drivers, not the new ones.)
VNeme
There's a new BIOS out today! Someone test it plz [I'm at work...]
updated, all worked for me, till now...
if i wont show up again, then this is it, thx
entilza
Bios for which board? For the P8Z77-V LK Asus's site isn't even giving me any drivers to download it's just blank..
