22968 Discussions
Intel HD 4600 crashes with BSOD when laptop wakes up Windows 10 (build 10162) VIDEO_TDR_FAILURE ( igdkmd64.sys )
abaue5
I have a ASUS N550JV laptop and has become almost useless bcs the graphic drives just freezes on wake up .
IS there any quick solution beside reverting back to old drivers ?
Thank you in advance
ASUS N550JV
Windows Insider Preview ( build 10162 )
Intel HD 4600 (integrated ) driver version 10.18.15.4235
Nvidia 750M (dedicated) 10.18.13.5330
Kevin_M_Intel
Hello Arthur-B,
Please note that we do not have at this point drivers for Windows 10 as it is not an official Operating System yet. What happens if you try Windows 8.1?
It is also important to say that the computer you have uses a special driver since it has Hybrid Graphics. You can check more information about Hybrid graphics here:
http://www.intel.com/support/graphics/sb/CS-031103.htm http://www.intel.com/support/graphics/sb/CS-031103.htm
It is extremely important for you to get the drivers from Asus site directly as this driver contains special configuration that our generic drivers do not have.
Kevin M
abaue5
Hello Kevin,
Thank you for the quick response,
I saw that you already provide drivers for windows 10 , and I am talking about those drivers. If I try to install the drivers for windows 8.1 they do not install even in compatibility mood.
I can use the drivers form Asus of course but they are form 2013 and I was hoping to get more form my graphic card even it is integrated by using the newest that come form intel.
Thank you again,
Arthur B
Kevin_M_Intel
abaue5
Yes , and that is the driver I am referring to that causes the BSOD issue. Is there any more info I can help you with to identify the cause ?
Windows Insider preview will have RTM status in a matter of days now.
MDorf
I have the same problem on my lenovo t440s, it happens after wakeup from suspend but also switching screens with my dual screen setup.
i did not have this problem before looks like it is new in the latest intel driver or windows 10 build 10162.
Kevin_M_Intel
At this point there is no support for this driver since it is still a BETA version but I will pass this feedback to development.
Kevin M
abaue5
I am using the last build which would be RTM in 2 weeks build Windows Enterprise (10176) and the problem is persistent I am forced again to use the old drivers.
Thank you for the reply,
Arthur
ISadk
I'm seeing this with the final version of Windows 10 Enterprise and the 10.18.15.4256 driver. I was hoping that problems like this would be worked out before the launch.
MKva
The problem persist on build 10240 even after the driver update
Intel HD 4600 driver 10.18.10.3379.01 (old driver, works perfect ) (From ASUS)
Intel HD 4600 driver 15.40.4.64.4256 (new driver, doesn't work )
ISadk
I was able to get around it by updating the BIOS on my Elitebook 820
MKva
There is not BIOS problem, its f***cking driver...
AFedc
Sorry for double post. But seems this thread is more suitable for that report:
I have HD4600 GPU and I also have BSOD when my my desktop PC wakes up
Here is archive with a few crash dumps https://onedrive.live.com/redir?resid=C3F8BA2FB83BBD05!28393&authkey=!AJIDGec-uPbhWAE&ithint=file%2czip intel_hd_4600_15.40.4.64.4256_dumps.
AFedc
JDoya
The problem with doing that is MS will 'conveneinetly' update your Intel driver.
You also need to defer Windows Update for your changes to 'stick'. Otherwise Windows will download the Intel driver again. Go into your Advanced Windows UPdate settings and check off "Defer Updates". Deferring updates disables updates of things like windows drivers and what were traditionally called "Optional" updates in Windows Update. Critical updates still get updated even if you check this option off.
AFedc
doyama, if you install driver manually through device manager then WU will not try to update it.
abaue5
The latest WU update on the Intel driver solved all my problems ... I hope for you guys as well.
JDoya
I can't seem to prevent Windows10 from updating it unless I click the Defer Updates. I can try to test a bit more but the Defer was the only reliable way I could find.
JDoya
I had high hopes the WWDM drivers would solve my issue
Unfortunately it did not... Still crashing on sleep.
BR4
Hey, you can use Microsoft "Windows update troubleshooter" tool to prevent windows 10 automatic updates for any particular update that is causing issues with your computer and that is what I did. I uninstalled the latest intel graphics update and rolled it back to Driver version 10.18.10.4252, problem solved. Run the Windows update troubleshooter afterward and "hide" the intel graphics update. You can download the tool from this page:
https://support.microsoft.com/en-us/kb/3073930 https://support.microsoft.com/en-us/kb/3073930
JDoya
I'm also having this problem on my Asus Ultrabook UX31L
Using the intel drivers the laptop sill bluescreen when coming out of sleep with various errors like igdkmd64.sys
Reverting to the "Microsfit Basic Display Adapter" does not cause this issue.
Reverting to an older Intel driver from Asus 10.18.10.3355 does not exhibit this problem
Thsi really needs to be addressed as without sleep mode my laptop is essentially a giant brick that I hve to leave plugged in and on constantly
