22974 Discussions
Intel HD 4600 screen tearing/flickering after updating to Windows 10 April Update
VTran8
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Screen flickering/tearing in games. Ghosting/blurry effect appears in Fortnite
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Dell Optiplex 3020MT
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
EFP
How much memory [RAM] in the system (see note2 below).
8GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
DP
Hardware Stepping (see note1 below).
<span styl...
Hello, UnluckyGod. Thank you very much for contacting the Intel Communities Team. I will be more than happy to assist you.
Please make sure you are using the recommended settings forhttps://gameplay.intel.com/en-us/CPUAndGameSelected/Index/75043/641893 Fornite* and https://gameplay.intel.com/en-us/CPUAndGameSelected/Index/75043/673546 StarCraft*. Please test these settings and share with us the results.
Antony S.
VTran8
Starcraft is fine now (without editing settings). But Fortnite still have problem.
Hello, UnluckyGod. Thank you very much for sharing the results.
Please try the drivers provided by your system manufacturer (4281). Here is the download link: https://downloads.dell.com/FOLDER03350146M/1/Video_Driver_Y9JM5_WN32_10.18.15.4281_A02.EXE https://downloads.dell.com/FOLDER03350146M/1/Video_Driver_Y9JM5_WN32_10.18.15.4281_A02.EXE
Let us know the results.
Antony S.
