23767 Discussions
Realtek Intel SST driver does not work.
ВШаше
Good afternoon. I assembled a PC based on the motherboard ASUS Prime H310M-K. The latest version of Windows 10 is installed with all updates. There is no sound. After installing all the drivers, only 1 Realtek Intel SST driver does not work. I tried everything I can, there is no sound. How to be, what to do?
ВШаше
VEN_8086&DEV_A348&SUBSYS_86C71043
Hello VaAlSh,
I understand that you are currently having problems with the audio and you are unable to find the drivers for it.
Regarding that, you must look for the audio drivers on the motherboard manufacturer's website as they are the ones who provide this driver for the audio. You can find it in the following link which is your motherboard manufacturer's website for drivers & tools:
https://www.asus.com/us/Motherboards/PRIME-H310M-K/HelpDesk_Download/ https://www.asus.com/us/Motherboards/PRIME-H310M-K/HelpDesk_Download/
* Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there. *
After the download and installation, please make sure to reboot the system, this should give you audio from now on.
I hope this helps.
David V
Hello VaAlSh,
I am following up with your case and see that we have not heard back from you.
I would like to know if you were able to find the drivers in the motherboard manufacturer's website.
If you need more assistance do not hesitate to reply.
David V
