22944 Discussions
Intel HD 530 Driver Crash in Windows 7 64-bit
MWaqa
Dear Team
Please Help
I am new to forum. I tried looking for the similar issue/solution. But I dint find any. So I am posting it myself.
I think this is a graphics driver issue. Because once I uninstall the Intel Graphics Driver, the default Windows VGA driver is not causing any issue. Any help is appreciated. BTW, the system is custom-made for my requirements.
I tried these things before posting this:
Installed latest Intel Graphics Driver, latest beta driver, latest Graphics Driver from motherboard website. The error persists!
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Getting BEX64 error whenever I open and close Intel Graphics Control Panel. Getting the same error during:
1.WinSAT test while first boot after graphics driver installation
2.After closing Intel Graphics Control Panel
3.After closing DxDiag tool (64 bit)
4. Various apps like VLC player, Windows explorer
Does it fail every single time, or only sometimes?
If you can offer a % rate please do.
Every single time. 100%
Hardware (HW)
Brand and Model of the system.
Intel i7 6700K, Asus Maximus VIII Hero 16GB DDR4 2400 Hz, Corsir SSD 240 GB.
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No external graphics card.
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)<td style="border: 0px; f...
r3un1on
test with the Driver Version 4424 !
you can download it here... http://www.station-drivers.com/index.php?option=com_remository&Itemid=352&func=fileinfo&id=2161&lang=fr Intel HD & Iris Graphics Drivers Version 15.40.22.64.4424 WHQL
Hi MuhammadWaqas,
Let's try to narrow down the issue.
I noted you are using memories of 2400MHz; however, the processor recognizes properly RAM at 2133MHz at 1.2V. The graphics embedded might be affected by the speed of it.
I suggest you to get into the BIOS change memory speed; uninstall and delete the current graphics driver. Restart the system, install the version 4404 and give a try.
Intel® Beta Graphics Driver for Windows 15.40.20.4404
https://downloadcenter.intel.com/download/25848/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- https://downloadcenter.intel.com/download/25848/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40-
Let me know how it works.
Mike C
MWaqa
Dear Mike C
Thanks for reply
Ok iam try this wait for responces
Sure, I will.
Mike C
MWaqa
Dear Team
Issue Not Resolved Follow All Steps
I Thinks 64bit Winows Not Support For HD530 Driver
Hi MuhammadWaqas,
I downloaded and installed the driver 15.40.20.4404 (64bit) and it is working properly. Please run our Intel® System Support Utility tool and send me the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Note: How to attach a file
Click reply
On upper right corner click Use advanced editor
Lower right section click Attach
Mike C
Hi MuhammadWaqas,
Please let me know if you are still getting the issue. If yes, send me a picture (screenshot) of the error.
Mike C
Hi MuhammadWaqas,
I am following your case. Let me know if I can help you with anything else.
Mike
MWaqa
Dear Mike
Thanks For Reply
But Still Same Issue Not Resolved I Think Win 7 64bit Not Support Intel Z170 6th Gen Iam Install Win 10 64bit Working Fine
Hi MuhammadWaqas,
Send me the results of Intel® System Support Utility. I will try to help you.
Click reply
Mike C
Hi MuhammadWaqas,
Mike C
