23822 Discussions
Intel HD Graphics on Intel Core 1st Gen Processor
SSher1
I am using Lenovo Edge 15 0301 JKG Laptop
Config
i3 1st Gen
8 GB RAM
500 GB HDD
15.6 Display
Intel HD Graphics Adapter
While using Win7 I never faced any issue of hanging or laptop getting stuck most of the time. But after upgrading to Win 8 & 8.1 I started facing issues, first I thought that the issues are hardware related so I changed RAM, processors added more thermal paste to heatsink and left the bottom cover always open but still faced the issue so I was out of option and I started finding heatsink fan for the laptop as that was the last thing I didnt replaced and that was not available in Pakistan. Then I upgraded to Win10 and have had same problem the fan rotating on very high RPM's and my laptop getting stuck sometime after a min and sometime I can use it for longer period if I dont play games or do anything graphics related.
Win 10 got an upgrade and I tried to update but it was not happening so I contact Microsoft support and they did some changes and that got installed and with it the issue of fan rotating at extreme speeds got fixed and I was happy but the stuck issue remained as it is.
I again went to microsoft to see if they can help and found the same issue as mine at MS community and after discussion and posting my dump files to a support person the final verdict was that the display drivers are making issues they verified it by running "verifier" and comparing the dump files before and after.
I was instructed to find an updated driver and install that to fix the issue but after 3, 4 days of banging my head here and there didnt found any solution so the last resort is to contact you people and let you know about the issue and ask you people to resolve.
Please let me know what can I give to help you understand my issue.
Hello, Sheraz:
Thank you for contacting the Intel Communities.
I am sorry to hear that you are facing performance issues with your device.
In this case, for the codename Clarkdale (first generation Intel® Core™ Processors) the support is provided up to Windows 8, the drivers to be used on this platform with higher versions of this OS will be the default drivers from Windows.
Here you can find some additional information regarding this: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html# core http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html# core
Another way that you can go will be to roll back to the previous Windows version that was working fine for you (Windows 7* apparently).
Esteban C
Hello, Sheraz:
Esteban C
