23851 Discussions
Help with drivers, and graphics issues
AKiny
Hello, so I am wondering why I am not able to use a direct X greater than 10. I am also no longer able to play mine craft because of issues i'm getting from "pixel acceleration and open GL" I've been on windows previous versions with direct X 11, and able to play mine craft, but now I am stuck with this. I also feel like my drivers are out of date. Can someone please assist me?
Intel® HD Graphics (Core i3)
Report Date: 5/9/2016
Report Time[hr:mm:ss]: 22:43:30
Driver Version: 8.15.10.2900
Operating System: (6.2.9200)
Default Language: English (United States)
DirectX* Version: 10.1
Physical Memory: 2485 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 1306 MB
Graphics Memory in Use: 135 MB
Processor: x86 Family 6 Model 37 Stepping 5
Processor Speed: 2394 MHz
Vendor ID: 8086
Device ID: 0046
Device Revision: 02
* Accelerator Information *
Accelerator in Use: Intel(R) HD Graphics
Video BIOS: 2033.0
Current Graphics Mode: 1600 by 900
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 14.96 inches
Vertical: 08.27 inches
Monitor Supported Modes:
1600 by 900 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4C A3 4B 54 00 00 00 00
00 12 01 03 80 26 15 78 0A 85 95 99 57 4F 8F 26
21 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 20 2A 40 24 61 84 32 30 30 20
26 00 7E D6 10 00 00 19 00 00 00 0F 00 00 00 00
00 00 00 00 00 1E B4 02 74 00 00 00 00 FE 00 53
41 4D 53 55 4E 47 0A 20 20 20 20 20 00 00 00 FE
00 4C 54 4E 31 37 33 4B 54 30 31 30 30 30 00 26
* Other names and brands are the property of their respective owners. *
Thanks/
Hi akidnamedandy,
I would be glad to help you. I need to collect more information of your system. Please download and run our Intel® System Support Utility tool and send me the results. With these information I will try to solve the issue.
Available in the link below
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600 https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?product=91600
Mike C
AKiny
Okay. Sorry for the late reply. Here's the information the scan gave me. I didn't know how to attach it properly.
Operating System:Microsoft Windows 10 Pro(10.0.10586 Build 10586)Physical Memory (Installed):6 GBProcessor :Intel(R) Core(TM) i3 CPU M 370 @ 2.40GHzSystem Type:X86-based PCDisplay Adapter(s):Intel(R) HD Graphics8.15.10.2900System Manufacturer:Hewlett-PackardSystem Model:1439Network Adapter(s):avast! SecureLine TAP Adapter v39.0.0.10Broadcom 4313 802.11b/g/n5.60.350.23Disk(s):Generic- Multi-Card USB Device6.23 GB (available)10.0.10586.0WDC WD5000BEKT-00KA9T0254.08 GB (available)10.0.10586.0
Hi akidnamedandy,
The features supported by Intel® HD Graphics on your first generation Core™ processor are below:
More details on the link below
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005524.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005524.html
Pre-built systems require customized drivers from pc manufacturers. Now, on Windows® 10, it is easier and recommended to install the latest drivers provided with Windows 10 update utility.
Hewlett Packard support website is the following:
http://support.hp.com/us-en/drivers/ http://support.hp.com/us-en/drivers/
Mike C
