22649 Discusiones
Intel HD 530 artifacts in Lenovo Y-700
PGuto
Principiante
4.782 Vistas
Hi
I am receiving an artifacts from Intel graphics scaling the screen on Windows 10. Previously I thought it was NVIDIA card, but I turned off NVIDIA in BIOS and the problem still occured. To put it simply I have a frame 1 pixel thick around screen on which a problem occurs. If there are AA turned on the problem can magnify. I am attaching some movies. In my opinion the scaling of the display is at fault, it shows to much screen on edges where is some bad graphics held. Same problem on fullscreen and windowed, same while aataching a screen.
Alien isolation, frame, mostly on top seen while in the first cutsceene:
https://www.youtube.com/watch?v=-DbmhAl8IoA https://www.youtube.com/watch?v=-DbmhAl8IoA
Witcher 2, here are white artifacts on edges "multiplied" when AA is on:
https://www.youtube.com/watch?v=U_ds5hWEUh0 https://www.youtube.com/watch?v=U_ds5hWEUh0
https://www.youtube.com/watch?v=TpsafFtOmL0 https://www.youtube.com/watch?v=TpsafFtOmL0
https://www.youtube.com/watch?v=x7YRyoZCDVs https://www.youtube.com/watch?v=x7YRyoZCDVs
https://www.youtube.com/watch?v=GHtOz_N4E-c https://www.youtube.com/watch?v=GHtOz_N4E-c
Some free benchmark from Steam called Star Swarm test - artifacts seen on edges mostly when explosion occurs:
https://www.youtube.com/watch?v=fe4z-Kdj1wM https://www.youtube.com/watch?v=fe4z-Kdj1wM
Even if can't solve this problem, is there a chance to overscale the screen a bit so those pixels at fault will be out of visible screen? If I recall NVidia could do this, but now Intel HD graphics settings are more important than NVIDIA.
0 kudos
7 Respuestas
Empleados
3.087 Vistas
I would like to know more information about your system configuration and the problem with the game, please fill out the form as much as possible and I will try to replicate this issue: /thread/77761 https://communities.intel.com/thread/77761
Allan.
Empleados
3.087 Vistas
Allan.
PGuto
Principiante
3.087 Vistas
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
as above
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): x
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
LENOVO Y700-15ISK model: 80nv00bwpb
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
switchable graphics
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
error is shown on every model
How much memory [RAM] in the system (see note2 below).
8GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
no ...
PGuto
Principiante
3.087 Vistas
Unfortunetelly it did not help.
Is there a way to scale screen f.ex. 105% ?
I know it was possible on nvidia drivers but Intel drivers do not allow such thing.
Empleados
3.087 Vistas
At this stage, scale option is under investigation and this is not part of the graphics features. I recommend keep checking for future driver updates.
Allan.
Allan_J_Intel1
Empleados
3.087 Vistas
Were you able to test driver version 4474?
https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40]
Allan.
Responder
