23102 Discussions
Intel HD Driver Issue in Cinebench r11.5 and r15
Johann_M_
I assembled my new PC and testing all my components and see if they are working smooth as silk *A must thing to do
Here are my benchmarking/stress testing tools:
Intel Burntest
Intel Extreme Tuning Utility
Aida64 Extreme
My PC:
Intel Core i5 4690k running on stock 3.5ghz
Intel HD4600
Gigabyte z97mx Gaming 5 F5 Bios
G.skill 2x4gb DDR3 1600mhz CL9
Seasonic m12ii 620watts
2tb Seagate Barracuda
Windows 7 SP1 x64
Note that all my drivers are downloaded from Gigabyte Site
After i installed my drivers and checking my components these benchmarking/stress testing tools are good (1)Intelburntest, (2)AIDA64, (3)XTU
no bsods, no errors found. So i think my pc is in excellent working condition. When i ran my last software Cinebench r11.5 and r15. It started acting weird. I got low scores in CPU benchmark a 334CB. In r11.5 i got 4.20 (these score is consistent) So i thought my CPU is defective. So i tried again formatting and try not to install drivers. I ran again cinebench and i got my expected score. R11.5 = 6.25 and r15 = 566. I'm really annoyed what happened but now i'm suspecting that it's a software issue. Tried install Chipset i got my expected score. Then installed Intel HD Driver then dang! My score again is low 😞 Then i uninstall the Intel HD, and got my expected/right score. Then installed my drivers (except intel HD) i'm still getting the expected score. Then i tried downgrading my Intel HD (October 2015 to August 2015 driver) but still the same low score :(( Then i uninstalled again the August 2015 driver and tried my luck using July 2015 driver (the one im using right now) and voila! My cinebench score is back to my expected score.
Also take note: My gpu score in Cinebench r11.5 and r15 is 33.47 (my expected score) so these Intel HD drivers below was not affecting my GPU/Open GL score. Only affects my CPU score
So my suspect drivers are:
Intel HD 15.36.26.4294 (10/10/2015)
Intel HD 15.36.24.64.4264 (8/19/2015)
The one i'm using right now: Intel GPU still 33.40~
Intel HD 15.36.23.64.4251 (7/27/2015)
I hope it can be fix by next the update! 🙂
Michael_C_Intel2
Hi Johann,
We are aware of this issue and are investigating, I don't have an ETA on a fix as the issue is still being root caused.
Also in the future you need to go to our support community: https://communities.intel.com/community/tech
You can report your issues and get support in the Graphics forum.  This forum is devoted to game developers working on Intel Graphics.
-Michael
