22968 Discussions
Intel HD Graphic 4000 (last update driver) won't execute WINSAT DWM or WINSAT FORMAL in Windows 10 Pro
BOne
In Windows 7 Ultimate before, Winsat is running well. Now already upgraded to Windows 10 Pro, didn't works. If I change display driver to Microsoft Display Standard Driver for Windows 10, it works. Neither last driver from Intel nor Toshiba works. Thanks.
Hello, HerruEZ:
According to https://technet.microsoft.com/en-us/library/cc742140(v=ws.11).aspx winsat dwm and https://technet.microsoft.com/en-us/library/cc742136(v=ws.11).aspx winsat formal these two command prompts are intended to work with Windows Vista, Windows Server 2008, Windows 7, Windows Server 2008 R2, Windows Server 2012, Windows 8, I have confirmed that several platforms with Windows® 10 including an Intel® HD Graphics 4000 and the latest driver the command prompt won't go through.
Amy.
BOne
Dear Amy,
Winsat command referred to WEI(Windows Experience Index), GUI of Winsat. In my other laptop with other kind of Intel display adapter(Intel Graphics Media Accelerator 4500M), is fine. WEI works, Winsat command also works. Both use Windows 10, upgrade from Windows 7. I hope it will be corrected soon. It is not about manufacturer driver, I think.
Does the issue persists with this version https://downloadcenter.intel.com/download/25188/Intel-Graphics-Driver-for-Windows-10-15-33-?product=81499 Download Intel® Graphics Driver for Windows® 10 [15.33]?
Amy.
Hello, /thread/104455 HerruEZ:
I just wanted to check on your thread; were you able to install the driver mentioned before? Does the issue persist?
Amy.
