23801 Discussions
Intel HD Graphics 3000 update problem
System Information
Time of this report: 9/9/2016, 02:23:23
Machine name: USER-HP
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr.160516-0600)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Inspiron N5050
BIOS: BIOS Date: 08/03/12 11:29:22 Ver: 04.06.04
Processor: Intel(R) Core(TM) i3-2350M CPU @ 2.30GHz (4 CPUs), ~2.3GHz
Memory: 6144MB RAM
Available OS Memory: 6052MB RAM
Page File: 4143MB used, 7958MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1024 x 768 (32 bit) (1Hz)
Driver Name:
Driver File Version: ()
Driver Version:
DDI Version: unknown
Driver Model: unknown
Driver Attributes: Final Retail
Driver Date/Size: , 0 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B70EE0-4340-11CF-B123-B03DAEC2CB35}
Vendor ID: 0x0000
Device ID: 0x0000
SubSys ID: 0x00000000
Revision ID: 0x0000
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
Sound Devices
Description: Speakers / Headphones (IDT High Definition Audio CODEC)
Default Sound Playback: Yes
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_111D&DEV_76D1&SUBSYS_10280504&REV_1002
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: stwrt64.sys
Driver Version: 6.10.6341.0000 (English)
WHQL Logo'd: Yes
Date and Size: 5/27/2011 10:06:16, 528384 bytes
Other Files:
Driver Provider: IDT
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Communications Headphones (IDT High Definition Audio CODEC)
Default Sound Playback: No
Default Voice Playback: Yes
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Internal Mic (IDT High Definition Audio CODEC)
Default Sound Capture: Yes
Default Voice Capture: No
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Rec. Playback (IDT High Definition Audio CODEC)
Default Sound Capture: No
Cap Flags: 0x1
Description: Microphone / Line In (IDT High Definition Audio CODEC)
Default Voice Capture: Yes
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1C26
| Matching Device ID: usb\root_hub20
| Service: usbhub
Hello, corpusjunior:
Thank you for joining the Graphics Community.
I noticed that you already have the latest driver installed in your system, may I know what is exactly the issue that you are dealing with.
Amy.
Hello, /thread/106248 corpusjunior:
I would like know if you still require assistance in regard to this matter, and if you do, please let me know what is exactly the issue that you are dealing with.
The latest Intel® HD Graphics driver for your graphics controller is .4429, here you can check that information https://downloadcenter.intel.com/download/24970/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-32bit?product=81500 Download Intel® HD Graphics Driver for Windows* 7/8/8.1-32bit. FYI, the last four digits of the driver will indicate the version.
Amy.
