23851 Discussions
Intel HD Graphics 530 - Poor performance 4K
CBroo2
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Graphics performance is low with the latest driver at 1440p resolution when using "Second Display Only" mode. Dragging windows around the screen, the window maximize and minimize animations, as well as animations/activity in browsers such as typing a URL or scrolling on web-pages is very 'juddery'.
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
CLEVO N150RD [Scan.co.uk 3XS LG15 Performance GTX] https://www.scan.co.uk/3xs/configurator/geforce-960m-gaming-laptop-intel-skylake-15in https://www.scan.co.uk/3xs/configurator/geforce-960m-gaming-laptop-intel-skylake-15in
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
Yes. Nvidia GTX960M
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
LFP = Not sure. Issue only occurs in 2nd Display only mode.
EFP = Dell UltraSharp U2715H 27"
How much memory [RAM] in the system (see note2 below).
16GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc<td style="border: 0px solid black; padding: 0 5.4pt 0 5...
Hello, ImChrisBrooks:
I have moved your thread in order to isolate your case, that way you can have your own thread.
I noticed that you have an older Intel® HD Graphics version installed, so let´s try updating it just follow the instructions below;
See here for the latest Intel® HD Graphics driver https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 Download Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40] and use this method in order to ensure the installation of the driver http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html How to Manually Install an Intel® Graphics Driver in Windows® 10 &...
Is there any chance you can update your BIOS version? I tried searching for your computer model, but I could not find the BIOS files.
Amy.
/thread/106350 ImChrisBrooks,
Were you able to follow the suggestion mentioned above?
Amy.
