23734 Discussions
Intel HD Graphics 4000 Blu-ray problem
Dde_S1
lay dr Hello guys,
I hope you could help me with my problem..
I have an ASUS N76V laptop. There is no blu-ray player in it.
So I bought an extern blu-ray player.
After I installed the blu-ray player. I can run a check if my laptop
is compatible. It's called Cyberlink BD Advisor.
Almost everything passes the test. except the drivers.
I already installed the latest drivers. Still can't play blu-rays with my blu-ray player. Could anybody help me?
Is there a driver coming who makes this compatible?
Hope to hear from you soon,
Dirk
BLogs
I have the same problem with a Samsung N510R5E.
I've installed the latest drivers from Samsung...still fails.
Dde_S1
Thanks for your reply. I hope they can solve our problem.
DArce
Valued Contributor III
ddes, could you please provide the model of the Bluray player that you are using? And the versions of the drivers that you have tested with?
asichacker, could you please provide the model of the system being used, driver versions installed for video and bluray players?
Additionally, both of you, please provide the version of the of the software that you are using to play the Bluray and post here the dxdiag report from the system affected. To get the report, check on start menu, type dxdiag, enter and press on save all this information.
BLogs
I am using a Samsung NP510R5E-A02UB laptop with an LG CP40NG10 USB 2.0 Blu-ray player.
The driver is from Samsung's site 9.17.10.3875
DArce
Dde_S1
I'm using a LG CP40NG10 blu ray player.
My drivers are
Graphics Card Driver : 9.17.10.2828
Dirk
DArce
des, test using the latest video driver provided by Asus* for your system. They are posted here:
https://www.asus.com/Notebooks_Ultrabooks/N76VZ/# support_Download_30 https://www.asus.com/Notebooks_Ultrabooks/N76VZ/# support_Download_30
Also install the latest Intel Management Engine Interface posted there too.
If the issue persists, please provide the version of the of the software that you are using to play the Bluray and post here the dxdiag report from the system affected. To get the report, check on start menu, type dxdiag, enter and press on save all this information.
Dde_S1
Oké. Here is my dxdiag. I have installed intel management. That program told me to install the latest
drivers. so now I have the latest drivers I guess. But I still have the same problem.
I can also post my log from Cyberlink BD Advisor.
System Information
Time of this report: 6/12/2013, 22:25:12
Machine name: DIRK
Operating System: Windows 8 64-bit (6.2, Build 9200) (9200.win8_gdr.130410-1505)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: N76VJ
BIOS: N76VJ.202
Processor: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz (8 CPUs), ~2.4GHz
Memory: 6144MB RAM
Available OS Memory: 6030MB RAM
Page File: 2046MB used, 5007MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_14771043&REV_09
Display Memory: 1664 MB
Dedicated Memory: 32 MB
Shared Memory: 1632 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Algemeen PnP-beeldscherm
Monitor Model: unknown
Monitor Id: CMO1720
Native Mode: 1920 x 1080(p) (60.010Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2875 (English)
Driver Version: 9.17.10.2875
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: Thread group
Driver Attributes: Final Retail
Driver Date/Size: 6/12/2013 19:05:59, 12615168 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-1174-7A34B4C2C435}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x14771043
Revision ID: 0x0009
Driver Strong Name: oem96.inf:5f63e5341859ec8c:iIVBM0:9.17.10.2875:pci\ven_8086&dev_0166&subsys_14771043
Rank Of Driver: 00E00001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/...
DArce
Dde_S1
Hi, thanks for your reply. didn't know you already replied. because i didn't got a notification by e-mail.
I tried to install the latest driver. But I got an error.
Oké that's in dutch. But it is saying it is not validated for this pc. Ask supplier for the right drivers.
Installation will be closed
Dde_S1
I managed to get my error in english. So its easier for you to know what it is.
DArce
Thank you ddes.
Please be aware that we provide generic drivers that have not been developed or tested specially for your system.
If you still need to use the generic drivers, you can try to force the generic driver by uninstalling the driver that was provided by your laptop manufacturer, this is done through the Control Panel, go to programs and features. Then locate any entry similar to Intel® Graphics Media Accelerator or video driver and remove it. After that, restart your system and try to install the generic driver again.
You can also try to force the driver with the instructions on this site:
http://support.intel.com/support/graphics/sb/CS-022355.htm http://support.intel.com/support/graphics/sb/CS-022355.htm
For this use the zip file posted on the same URL I gave you
Dde_S1
Ok. I have uninstalled my drivers and now I have the latest driver (9.18.10.3165).
I plugged in my blu-ray driver. But I still got the same problem.
This is the error .>>
On other pc's and laptops
the blu-ray disc works and plays.
Dirk.
Thanks so far, now I have at least the latest drivers
DArce
That seems to be related to the format of the disc not a problem indicating issues with the video driver.
Try changing the DVD format/region using the information posted here:
http://technet.microsoft.com/en-us/library/cc757394%28WS.10%29.aspx Change region settings for DVD drives: Management Services
Dde_S1
It is an issue with video driver. DVD is working on other pc and laptop. But not on my laptop.
The problem should be there as well, if it was a problem with the disc.
I have tried changing dvd region.. It didn't help. I'm very disappointed. Intel has good motherboards, but
Intel onboard graphics card is crap. I do recommend everybody not to buy a laptop with Intel onboard graphics card.
I hope you do have a solution. By the way there was a new driver. I updated my laptop with the newest driver and still got the problem.
Dirk
DArce
What is the driver version that is being used by now?
Has anything changed on what is installed in the system since your last reply in July?
