23826 Discussions
Intel HD Graphics 4600 - How to downgrade drivers?
JSalv2
Hey, everybody. I've been having a problem over the last two days. I want to install this https://downloadcenter.intel.com/Detail_Desc.aspx?lang=eng&DwnldID=23714 Intel® Download Center driver as the latest drivers have been causing issues with Minecraft. However, when I run the exe it says Your computer does not meet the requirements to install this software. Which is strange, because I have had the latest driver before. I am searching everywhere on how to install the driver but to no avail.
Silvia_L_Intel1
Hello OrganicOrange, thank you very much for contacting us. Regarding your situation the following URL will give you some steps you can follow in order to solve the error you are getting "System does not meet minimum requirements" http://www.intel.com/support/graphics/sb/CS-034659.htm Graphics — Error messages seen when installing Intel® Graphics Drivers
I was checking the Intel Download center and I couldn't find a previous driver version. There is a newer version 3621 that you may want to try, but I cannot assure you it will solve the problem you are having.
Please let me know how it goes.
Silvia L
