23282 Discussions
Intel HD Graphics 4600, getting message that "Display is not compatible" when I attempt to upgrade to Windows 10.
bpric4
Not sure what to do with this. I upgraded to the most current 4600 driver for Windows 8.1 yet the WIndows Upgrader program still says Windows 10 is not compatible. And, I can't install the newer Windows 10 version of the driver.
What to do?
CCris2
New Contributor II
Hi Bradtri ,
What windows version you have ? For windows 10 you can install this driver : https://downloadcenter.intel.com/download/25957/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=80939 Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40]
First you need to uninstall old driver.
Were you able to install the driver version 4444?
Allan.
bpric4
Both 4424 and 4444 give the reply "computer does not meet minimum requirements". I'm trying to install the 64 bit version of the driver. Below is my system info:
CCris2
New Contributor II
Yes you are using windows 8.1 and you are trying to install windows 10 drivers ... You should install windows 8.1 drivers: https://downloadcenter.intel.com/download/25978/Intel-Graphics-Driver-for-Windows-7-8-1-15-36-?product=81496 Download Intel® Graphics Driver for Windows 7*/8.1* [15.36]
bpric4
hmmm... in the description of 4424 and 4444 it lists Windows 7 and 8.1 along with 10, so I figured it should work. At any rate, I installed 4414 per your recommendation but still get the same error when running the Windows 10 Updater utility:
CCris2
New Contributor II
They are for win 7, and 8.1 but for broadwell and skylake. For Haswell they are only for windows 10
CCris2
New Contributor II
Try install and older driver that came with your pc. I upgraded to windows 10 on a haswell pc with an older video driver. If it doesn't work then your windows may have a problem....
You can try uninstall completely the driver with this utility: http://www.guru3d.com/files-details/display-driver-uninstaller-download.html Display Driver Uninstaller Download version 16.0.0.2
Select Intel at Graphic Driver.
Then click on Clean and DO NOT Restart.
And then Set Automatic Installation Driver to default. And after that restart.
Then install the driver.
bpric4
I ran the DDU utility. After the restart, it took a while, but things came around. I'm now at driver 4264 from Aug 2015, but still no luck with the Windows 10 upgrade.
Thanks for your help, but I'm starting to think the best course for me is just to ride 8.1 for another year or two and then I'll probably be upgrading to a new desktop.
CCris2
New Contributor II
Hmm. What if you don't install any driver, and leave the default windows driver ?
CCris2
New Contributor II
Your system should be able to run windows 10 with no problem. It's just something wrong with your windows. Do you have an antivirus ?
bpric4
I did not specifically install any driver. I assume that is what happened from the "Set Automatic Installation Driver to default".
I do run McAfee anti-virus
CCris2
New Contributor II
Try disable antivirus, and check again. This problem you have should not happen. You can also try to upgrade from the webpage https://www.microsoft.com/en-us/windows/windows-10-upgrade How to Upgrade to Windows 10 - Microsoft it will install a newer update.
bpric4
No dice ... turned off Real Time Scanning and the McAfee firewall. Downloaded the new upgrader and still get the same error.
CCris2
New Contributor II
I found out what your problem is.
Have you done all windows 8.1 updates ?
You need compatibility patch for windows 8.1 to windows 10: KB2976978.
So go in Control panel Windows update and install optional updates.
bpric4
Hey Ronin,
I really appreciate all your help on this. I'm at work today but will check for the patch when I get home.
bpric4
Well ... good news and bad news.
I was able to find the optional update KB2976978 and sure enough, it was not installed on my machine. I installed it and restarted.
Unfortunately, the WIndows 10 upgrader utility still gives me the same error message.
A couple things. I have a bucket load of "recommended" updates that are not installed as I was set to only install "important" updates. Should I install the whole pile of recommended updates? (Scares me a fair amount). Or, are there perhaps other specific patches that could be applied at this point?
Or, now that KB2976978 is installed, should I be trying some of the other Intel 4600 Graphics drivers? I'm sitting at 10.18.14.4264 right now.
CCris2
New Contributor II
You should install all updates
bpric4
I applied all 87 updates tonight and ........ still the same response for the updater utility. I tried installing a few of the different versions of the graphic driver that we had tried ... interestingly, a couple of them now said "my machine didn't meet minimum requirements" for the driver. So, pretty much had given up.
Then, came back to my machine an hour or so later, and the automatic Windows 10 upgrade window was displayed saying that my machine was compatible with Windows 10 and when would I like to schedule the upgrade. I went ahead and scheduled for tonight ... we'll see what happens. Still, when running the upgrade utility manually it says the display is not compatible....
CCris2
New Contributor II
bpric4
And the final answer is ... the Windows 10 upgrade ran successfully last night.
Ronin - thanks again for all your attention to this and getting me squared away.
