23082 Discussions
Intel HD Graphics 515 external displays not working with USB-C Dock
KStoc1
I have a ThinkPad X1 tablet 20GG001KUS with a Lenovo USB-C dock. I have two external ThinkPad monitors connected to the dock. Everything worked fine for a while, however, now the external monitors are not working with the dock. They do work when I connect individually to the mini display port on the tablet.
Its not the cable or the dock since I have two offices with the same setup and I have the problem using both.
The graphic driver has been recently updated to driver 25.20.100.6576
Is there a way to reset the graphic drivers to see if that will help?
AlHill
Use the lenovo graphic drivers, and if the dock needs to be updated, do so.
Doc
