23527 Discussions
Intel HD Graphics 520 Not Supporting Latest Driver v.15.45.14.4590
BMaju
This morning just found new driver v15.45.14.4590 released for Intel 6th & 7th gen. graphics . . Since mine one is Intel HD 520 [i7 6th Gen.] [[Hardware ID: PCI\VEN_8086&DEV_1916&SUBSYS_81EC103C&REV_07]] .
Downloaded the driver , but while installing it's showing the following compatibility issue .
Any solution ? I'm using HP Notebook 15-AY078TX Laptop .
Stefan3D
Check out: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows...
BMaju
@ Stefan3D , , , , tried this method too , it did not accept anything to install
BMaju
Well, problem solved ! . . . Just installed previously installed 21.20.16.4550 & tried again , now installed successfully
Hello IamBidyuT,
I'm glad that your issue has been resolved and thank you for taking your time to post how your solved the issue.
Ivan.
sdey1
which one is updates driver version for intel hd 520
21.20.16.4550 or 15.45.164627
The latest driver version is 15.45.164627.
Ivan.
