23854 Discussions
Intel HD Graphics 530 driver causing screen flickering
MSoh1
Amy_C_Intel
Hello, locolyric:
The "Display Driver Stopped Responding and Has Recovered" issue has been replicated, and Intel is working to get this issue fixed.
In the meantime, please try the following workaround;
  1. Open the Device Manager.
  2. Expand the Display Adapters section.
  3. Find the Intel Graphics Driver.
  4. Right click Intel Graphics Driver and select Uninstall.
  5. Select the check box Delete the driver software for this device.
  6. Reboot the computer after uninstall process has finished.
Once you have rebooted your computer, install this driver version https://downloadcenter.intel.com/download/25848/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Beta Graphics Driver for Windows* 7/8.1/10 [15.40], with this method http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html How to Manually Install a Graphics Driver in Windows 7*.
Amy.
MSoh1
After install the latest driver as your reply, problems still exist.
Amy_C_Intel
locolyric, please try with this driver version https://downloadcenter.intel.com/download/25957/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?v=t Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40], which is intended to fix this issue. Follow the method mentioned above for the installation.
Amy.
MSoh1
After two months of using version .4444, most of the desktop were working fine. But there is another 2 new AIO facing the same issue again . Hope 4474 will fix it.
Amy_C_Intel
I am glad to hear that the driver is working fine. Yes please try with the latest version and let me know how it goes.
Amy.
MSoh1
Should I re-create a new form to report? with current update(4474), user had another symptom with Excel(again). This symptom won't stop happen while on version 4444. Luckily it only happen once with version 4474.
While user editing excel, some times all items on ribbon were not able to click anymore,user cannot click on all of these option except close button.
By symptom you mean "Display Driver Stopped Responding and Has Recovered"?
Amy.
MSoh1
"Display Driver Stopped Responding and Has Recovered" issue stop produce after we upgrade to beta 4444.
The latest symptom were " command in excel 2010 ribbon freeze" , if user minimize and restore back for few times, all button will become clickable again.
locolyric, and have you tried with a different Excel version?
/thread/101339 locolyric, I justed wanted to check on your thread; does the issue persist?
Amy.
