23847 Discussions
Intel HD Graphics Driver Crashes Windows
JJack12
Hello.
Recently I installed Windows 10, again, and got an error which I got when I tried to install Windows 10 three times before. Back then I was too lazy to try and fix the issue, went back to Windows 7 and waited for another Windows 10 update.
Nothing changed! The error I got was the bluescreen with error message: "SYSTEM_THREAD_EXCEPTION_NOT_HANDLED (igdkmd64.sys)" after a few seconds after boot.
So I researched and found out that my Intel drivers is the problem. So I grabbed myself a DDU(Display Driver Uninstaller) software and uninstalled all Intel drivers. After that I downloaded Microsofts tool for hiding drivers from Windows 10 update. After that everything works fine and I'm currently on my computer. My only problem is that I can't install my Video Controller(Intel HD Graphics) drivers because the system than immidiatley after installation crashes with the bluescreen. Without my Video Controller I can't connect two monitors which is really bad and if there is no solution to this problem I will go back to Windows 7.
It would be great if you could tell me how to fix this issue.
Hello, jjhelps:
Could you please let me know your computer model, processor model and the driver version you are trying to install?
Amy.
Hello, /thread/104864 jjhelps:
I wanted to follow up your thread; were you able to fix the bluescreen?
Let me know your findings.
Amy.
