22668 토론
Intel HD Graphics 530 won't recognize native resolution
leotruss
초급자
5,528 조회수
I have a 1920 x 1200 native resolution Asus PA248QV monitor that is connected to an integrated Intel HD Graphics 530 card. This resolution was not recognized by the graphic card, and it kept defaulting to 1920 x 1080. There is no option to choose 1920 x 1200 resolution either in the drop-down menu in the Windows Display setting or in the Intel Graphics Command Center.
I've uninstalled and reinstalled the driver, but the problem persists. Can this graphic adapter support 1920 x 1200, or is there a problem with my configuration? Any help would be greatly appreciated.
0 포인트
13 응답
n_scott_pearson
수퍼 사용자
5,513 조회수
What driver version are you trying? According to what I can see, you should be using v31.0.101.2115 (available here: https://www.intel.com/content/www/us/en/download/762755/intel-6th-10th-gen-processor-graphics-windows.html).
Hope this helps,
0 포인트
leotruss
초급자
5,488 조회수
Thanks, I've updated to the v31.0.101.2115 driver, but it's still not working. Also, I did a clean uninstall and installed the latest version of the driver, thinking the old driver was causing the problem. With graphics and command center's "Scale" function set to "Maintain Display Scaling", I can resize it to full screen. I am not sure if artificially stretching the resolution to fit the screen is the correct approach to resolving this issue. In the display menu, there seems to be no option to choose beyond 1920 x 1080; is this the maximum resolution the graphics card can display? Any further assistance would be greatly appreciated.
0 포인트
n_scott_pearson
수퍼 사용자
5,476 조회수
Hhmmm, what are you seeing in the EDID data being returned by the monitor? You can use a tool like NirSoft's MonitorInfoView tool (available here: https://www.nirsoft.net/utils/monitor_info_view.html) to display this information.
0 포인트
leotruss
초급자
5,471 조회수
I have attached the detailed report generated by MonitorInfoView for your review (screenshot). Appreciate you taking the time to look at it.
0 포인트
leotruss
초급자
5,371 조회수
Having no luck trying to resolve this resolution problem, is there any Intel staff here who can help? Thanks in advance.
0 포인트
n_scott_pearson
수퍼 사용자
5,355 조회수
Is this perhaps a laptop? There are known cases where attached displays are artificially limited to the same resolution as the embedded display in the laptop.
From here, we will need more information. Please download and run the Intel System Support Utility for Windows. When you start the utility, select Everything and then click on Scan. Once it completes the scan process, click on Next and then Save. Pick a name for the text file to create and click on Save to create it. You can then close the app. Finally, open a response post here and then, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
0 포인트
leotruss
초급자
5,310 조회수
It is a desktop computer with four monitors attached. Three of these monitors are connected to an Nvidia Geforce GT 730 graphic card and had no problems with resolution settings. There is only one monitor connected to the Intel HD Graphics 530, which is 1920 x 1200.
0 포인트
VWFeature
초급자
2,875 조회수
Have you tried the NVIDIA Mosaic utility? You may be able to get them all on the NVIDIA, possibly w a DP/HDMI splitter available on Ebay for ~$8
www  dot  nvidia dot com/en-us/design-visualization/solutions/nvidia-mosaic-technology/
NVIDIA MOSAIC. Whether you want to see your work across multiple displays or project your ideas in 4K, you can with NVIDIA Mosaic ™ multi-display technology. With NVIDIA Mosaic, you can easily span any application across up to 16 high-resolution panels or projectors from a single system, conveniently
I'm no expert, but this seems to have magic powers.
0 포인트
n_scott_pearson
수퍼 사용자
5,255 조회수
So, when I see 1920x1080 being supported at up to 75Hz and the EDID saying that 1920x1200 is (supposed to be) supported at up to 60Hz, it makes me wonder whether the HDMI cable is up to snuff. Do you have another quality HDMi cable that you can try?
I will also ask: has this ever worked?
0 포인트
leotruss
초급자
5,230 조회수
This HDMI cable came with the Asus monitor, so I assume it should work as it showed me a 1920x1200 resolution when I ran it under the Nvidia card. Also, I replaced this cable with the Dell monitor cable (which ran 1920x1200 resolution without problem on Nvidia) on the Intel HD530 graphic card and it's still not displaying 1920x1200 resolution.
0 포인트
n_scott_pearson
수퍼 사용자
5,202 조회수
Hhmmm, does your motherboard have a DisplayPort or Thunderbolt port? You can use this as an alternative and get away from the crappy HDMI support Intel's older processor provided.
0 포인트
leotruss
초급자
5,138 조회수
In the case of this model (Inspiron 3650) there are only two ports: a HDMI and a VGA. I also used a VGA to HDMI cable but was not able to achieve the desired 1920x1200 resolution.
0 포인트
DeividA_Intel
직원
5,056 조회수
Hello leotruss,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request. Thank you for understanding.
Discontinued Products: https://www.intel.com/content/www/us/en/support/discontinued-products.html
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
0 포인트
응답
