22955 Discussions
Intel HD Graphics 5500 defaulting after restart
DDeba
Intel HD Graphics 5500 defaulting the display to 1024 X 768 in Windows 10 whenever the computer boots. I have to change the display settings to full screen every time I log in to the full screen resolution 1920 X 1080. Can this be set permanently? I am using Dell Inspiron 17 5000 series.
Appreciate any help.
Hello @Blue_View,
I would like you to install the latest drivers released by Intel.
Please download them here: http://intel.ly/2eP7whk http://intel.ly/2eP7whk
Then disconnect the system completely from the Internet connection (important step)
Finally, follow the steps here: http://intel.ly/1PdmvLd http://intel.ly/1PdmvLd
Please let me know how the computer behaves after doing this.
Esteban C
DDeba
Dear Intel/Esteban,
Thanks a lot for your detailed response.
I have performed the steps. When I tried to update the driver from the downloaded file, the system raised the message "Windows has determined that the driver software for your device up to date".
Nevertheless, I restarted the computer, but the issue is not resolved and still persists. The Display again went back to 1027 X 768. Then I had to open the "Intel(R) HD Graphics Control Panel" shortcut from my desktop then click Display, change the setting.
Can you please let me know the next steps.
Appreciate your help.
Once you restarted the computer, what was the driver reflected for you graphics adapter?
This can be checked by following the next steps:
1. Access the device manager.
2. Look for "display adapter"
3. Right click on "Intel HD Graphics 5500"
4. Hit properties and look for the driver tab
Please double check the driver installed is the same version as the one you tried to install (last 4 digits)
Esteban C
DDeba
Hi Intel/Esteban,
Thanks a lot for responding back. The driver is showing as 20.19.15.4454
The version which was shown on your link is Version: Beta 15.40.xx.4539 (Latest)
Please let me know if you need more information.
I really appreciate your response and constant support.
Thank you for the answer!
I recommend you to use the manual installation again, this time, please make sure you do not have internet connection while installing the drivers.
Manual installation steps: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html
Driver: https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=86210 https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=86210
If the problem persists (not able to install them) please contact the manufacturer of the device, some OEMs (manufacturers) limit the drivers that can be installed on their systems, for that reason you can pin them in order to get the latest drivers from their side and possibly a fix for the current issue related to resolution.
Esteban C
DDeba
Hi Intel/Esteban,
Thanks a lot for the response. When tried to update, I got the following message. I have checked the website of Dell (my OEM), and I have the latest version of the driver as per the site.
Thanks for the update!
Have you tried with a custom resolution? Set it to 1920x1080 apply and then restart.
If you are still having issues after doing so, I believe it would be good to reach your OEM in order to get further troubleshooting related to the resolution "reset."
We have tried to install the beta driver without success which indicates there may be a block from installing third party or generic drivers in your device.
Please let me know how it goes with them if required.
Esteban C
I just wanted to verify if the recommendations given above worked for your issue.
Esteban C
DDeba
Hi Intel/Esteban,
Thanks a lot for the follow-up. I am really sorry that I could not update you.
I have tried the option, but the issue is not resolved.
Thanks for the answer! And more than welcome!
At this point, we have tested with our generic driver 4539, used manual installation and tested with a custom resolution.
Have you tested the behavior of your device with the default drivers from Windows10*?
You can get them after following these steps:
1. Access the device manager and look for display adapters
2. Right click on Intel HD Graphics 5500 and hit properties
3. Go to driver tab and uninstall the drivers (make sure you select "Delete the driver software for this device")
4. Restart the system and Windows 10* and run Windows updates
-Have you tested different cables?
-Is this happening with other monitors or TVs?
If the problem persists after this, we can say it is not a driver issue, from Intel and Windows 10* sides, so what would be left as the issue is the OS or drivers from the OEM.
For that reason, it would be good to check with your OEM (manufacturer of the device such as Dell*, Lenovo*, HP*, etc...) in order to get further troubleshooting and/or drivers to be used.
Please let me know how it goes.
Esteban C
I am here to check if you were able to proceed with the recommendations provided in my last answer.
Please let me know 🙂
Esteban C
DDeba
Hi Intel/Esteban,
Sorry for my late reply.
The issue was not resolved by the mentioned steps. The only change happened is that, I could have a Intel HD Graphics icon at the desktop, which disappeared.Now I open the console by doing a right click on the screen then going to graphics.
Please let me know if you want me to do any other step.
Even if the issue is not resolved, I appreciate the helpfulness of you and the eagerness to resolve the problem. This is undoubtedly appreciable.
Hello Blue_View,
Thank you for the answer provided!
I would like to verify the following:
1. Were you able to use the default drivers from Windows and check if the resolution* changed after restarting the system?
2. Did you test the system with other cables?
3. Did the system was tested with other TV/Monitor?
4. Was the OEM contacted to report the issue and get troubleshooting?
Note*: While having the default drivers, you can change resolutions with right click, select display settings, go to advanced display settings.
I am more than glad to assist you with this! Please let me know (the info above)
Esteban C
Hello Blue_View,
In order to further help you, could you please provide is with the following information:
I am looking forward to hearing from you.
Best regards.
Hello Blue_View,
I would like to check if you were able to see my last answer in order to verify if you require any further support.
Esteban C
Hello Blue_View,
Just wanted to double check if you still require support for this matter.
Esteban C
DDeba
Sorry for the late reply.
The issue is not resolved.
Hello Blue_View ,
I understand, could you please double check my last recommendations?
Important: Please provide me with the graphics report from your system:
Instructions on how to get the report: http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html
Esteban C
Hello Blue_View,
Just wanted to verify if you were able to see my last answer.
Please let me know how it went.
Esteban C
DDeba
Hi Esteban,
Sorry for the late reply and really appreciate your help.
Here is the report.
Intel(R) HD Graphics 5500
Report Date: Wednesday, January 25, 2017
Report Time [hh:mm:ss]: 7:53:30 PM
Driver Version: 20.19.15.4454
Operating System: Windows* 10 Home (10.0.14393)
Default Language: English (United States)
Physical Memory: 8102 MB
Vendor ID: 8086
Device ID: 1616
Device Revision: 09
Graphics Output Protocol (GOP) Version: 5.5.1028
Current Resolution: 1920 x 1080
Processor: Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz
Processor Speed: 2394 MHz
Processor Graphics in Use: Intel(R) HD Graphics 5500
Shader Version: 5.0
OpenGL* Version: 4.4
OpenCL* Version: 2.0
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 11.1
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 14.96 inches
Vertical Size: 8.27 inches
Supported Modes
1920 x 1080 (60p Hz)
1920 x 1080 (48p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 06 AF 9D 11 00 00 00 00
00 19 01 04 90 26 15 78 02 C8 95 9E 57 54 92 26
0F 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 84 3A 80 34 71 38 28 40 30 64
31 00 7D D6 10 00 00 1A E0 2E 80 34 71 38 28 40
30 64 31 00 7D D6 10 00 00 1A 00 00 00 FE 00 38
37 47 4E 4D 80 42 31 37 33 48 54 4E 00 00 00 00
00 00 41 22 96 01 11 00 00 02 01 0A 20 20 00 57
* Other names and brands are the property of their respective owners.
I could not see any option to use Default driver.
I have not contacted the OEM so far. I have not used any other display to test this.
Please let me know if you need more information from me.
