22643 Discussions
Intel HD Graphics 5500 defaulting after restart
DDeba
Intel HD Graphics 5500 defaulting the display to 1024 X 768 in Windows 10 whenever the computer boots. I have to change the display settings to full screen every time I log in to the full screen resolution 1920 X 1080. Can this be set permanently? I am using Dell Inspiron 17 5000 series.
Appreciate any help.
Thanks for the info, Blue_View
I noticed you have an old driver, please test the behavior of the system with the latest released.
Here: https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=86210 https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=86210
Make sure you download the .zip version of the drivers
In order to make sure you get it installed properly, please follow these steps:
1. Access the device manager and look for display adapters
2. Right click and select update driver for Intel HD Graphics 5500
3. Select "Browse my computer for driver software"
4. Select "Let me pick from a list of device drivers on my computer"
5. Click on "Have Disk" and find the .zip driver folder downloaded
6. Go to "Graphics" folder and select the .inf file and hit open then ok
7. Select Intel HD Graphics 5500 under "model" and hit next
Please let me know how it goes.
Esteban C
DDeba
Thanks a lot for the prompt reply.
I have performed the update as mentioned.
Here is the latest report.
Intel(R) HD Graphics 5500
Report Date: Thursday, January 26, 2017
Report Time [hh:mm:ss]: 12:30:03 AM
Driver Version: 20.19.15.4539
Operating System: Windows* 10 Home (10.0.14393)
Default Language: English (United States)
Physical Memory: 8102 MB
Vendor ID: 8086
Device ID: 1616
Device Revision: 09
Graphics Output Protocol (GOP) Version: 5.5.1028
Current Resolution: 1920 x 1080
Processor: Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz
Processor Speed: 2394 MHz
Processor Graphics in Use: Intel(R) HD Graphics 5500
Shader Version: 5.0
OpenCL* Version: 2.0
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 11.1
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 14.96 inches
Vertical Size: 8.27 inches
Supported Modes
1920 x 1080 (60p Hz)
1920 x 1080 (48p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 06 AF 9D 11 00 00 00 00
00 19 01 04 90 26 15 78 02 C8 95 9E 57 54 92 26
0F 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 84 3A 80 34 71 38 28 40 30 64
31 00 7D D6 10 00 00 1A E0 2E 80 34 71 38 28 40
30 64 31 00 7D D6 10 00 00 1A 00 00 00 FE 00 38
37 47 4E 4D 80 42 31 37 33 48 54 4E 00 00 00 00
00 00 41 22 96 01 11 00 00 02 01 0A 20 20 00 57
* Other names and brands are the property of their respective owners.
Please let me know your opinion. In the meantime, I will keep an eye on the issue. If the issue is resolved, I will let you know.
Hello Blue_View,
Understood, I will keep the thread handy to follow up on the inquiry.
Esteban C
Hello Blue_View,
I am here to double check if the issue has been resolved.
Esteban C
Hello Blue_View,
I would like to double check if you still require support for this matter.
Esteban C
