I have a problem with my laptop (Intel Core i7-5700HQ with Intel HD Graphics 5600) in which if I use application that use Qt, the application's GUI will stop working after several seconds.
- VirtualBox
- I use VirtualBox 5.0.20
 - As you can see in the attachment, after I move my cursor over the menu several seconds the menu will be not displayed sometimes and the blue mark also not there if I hover my cursor over specific menu.
 - If I close VirtualBox and restart again it will not work as the previous process is still not responding in task manager.
 - I've asked support from VirtualBox community and they said that it was Qt issues because VirtualBox use Qt for the GUI and they also said there is a problem with my current graphics driver to communicate with apps that use Qt
 - I've tried to replicate issue in another application that use Qt in which I use Wireshark in this case
 - Wireshark
- I use Wireshark 2.0.3 that use Qt 5.3.2
 - As you can see in the attachment, this one is even worse than VirtualBox. After several seconds hovering my cursor accross menu the application is not responding at all and I need to force close via Task Manager
I've tried to replicate issue with my other laptop which has intel HD Graphics 5500 both applications work fine, so my conclusion is something wrong with Intel HD Graphics 5600 itself.
I've tried all driver versions Intel HD Graphics 5600 but it doesn't help at all. Now I use latest beta driver (4444) and the problems still there.
So basically I can't use both applications above at all because it will stop responding after several seconds and it's bothering me because I need both applications for my work.
If you need more data let me know.
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
See above
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Intel Core i7-5700HQ - Int...
链接已复制
Hello, iede:
Thank you for contacting the Intel Communities and for providing us with such detail information about the issue you are encountering with.
I would like to inform you that I will be trying to replicate this on my end in order to further assist you on this matter.
Will keep you posted on my findings.
Esteban C
Hello, iede:
I would like to verify if you are still having this issue?
Also, Intel has released new drivers recently, have you checked?
Here I add them, how you can give them a try:
Beta 15.40.26.4474 // https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345
15.40.25.4463 // https://downloadcenter.intel.com/download/26078/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345 https://downloadcenter.intel.com/download/26078/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88345
Please let me know how it goes.
Esteban C
That sounds great iede!
I'm really glad you got this fixed.
I will be setting your last comment as "Correct Answer" to give a clousure to this matter.
If any further support is required, feel free to contact us back (this thread can be used if the same issue is present).
Esteban C
