23851 Discussions
Intel HD Graphics 620 update driver issue
SEnte1
Hello Team,
Today i downloaded Intel Driver and support assistant through i saw a notification of graphic update which i downloaded it. when i click for install it completes the process but after that it says incompatible graphic driver. Please tell why it is happening.
Hello shrisaienterprise,
I understand that you are having problems with a graphics driver update that says your system is incompatible.
Regarding this, To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
David V
SEnte1
Hi David V,
I Have attached the required file. Please check
Thank you for your response,
Please download the ".zip" file from the link below:
https://downloadcenter.intel.com/download/27680/Graphics-Intel-Graphics-Driver-for-Windows-10?product=96551 https://downloadcenter.intel.com/download/27680/Graphics-Intel-Graphics-Driver-for-Windows-10?product=96551
After the download is complete, please follow the steps below:
1 - Unzip the file to a designated location or folder.
2 - Right-click Windows Start icon and open Device Manager.
3 - Click Yes when prompted for permission from User Account Control.
4 - Expand the Display adapters section.
5 - Right-click the Intel® graphics entry and select Update Driver Software.
6 - Click "Browse my computer for driver software".
7 - Click "Let me pick from a list of device drivers on my computer".
8 - Click "Have Disk".
9 - Click "Browse".
10 - Access the designated location or folder, and access a folder called "Graphics".
11 - Select the .INF file (Information file).
12 - Click Open, then click OK, and finally click Next. Drivers are now being installed.
13 - Reboot your computer
After this, the tool should not show any update for the graphics controller pending.
Let me know the outcome.
David V
I am following up with your case and see that we have not heard back from you.
I would like to know if you were able to manually update the driver.
If you need more assistance do not hesitate to reply.
David V
BJules
I have the same problem, but the installation doesn't run because it's not compatible (with this zip file, and with any other way i found here).
I think it's due to my WDDM number, but i'm not shure.
(driver version 21.20.16.4627)
Here is my dxdiag, if someone can please help me...
