23106 Discussions
Intel HD Graphics 630 with 3 displays
PAmor
I'm trying to make a 3 monitor setup work with an intel HD GGraphics 630, but the Graphics control panel detects 3, but only allows for two of them.
The windows panel shows the 3 of them, but one of them is disabled, and as soon as you enable it, one of the others gets disabled.
Is it posible to get all three of them working?
I'm running the win64_154519.4678 driver and tried downgrading to win64_154514.4590
with the win64_154514.4590 it shows the 3 slots to extend the desktop and alows for three of them to be extending, but one of them is always black.
Hello DartaUY,
I understand you are trying to use three displays in your computer, but one of them is disabled.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Please also attach the Intel Graphics Driver Report. This link will show you how to generate it https://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html https://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html
Please run both reports with the three monitors connected to the computer.
What type of video cables are you using between the computer and the monitors?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
PAmor
I have it working now with an old nVidia graphics card that I had lying around, but i'm interested in not using it because it is old and from time to time it fails and forces me to reset the pc.
Hello DartaUY,
Thanks for the information you sent to me.
According to the specifications of the motherboard your system supports up to two displays simultaneously. You can confirm that information in the following link under the graphics section http://www.asrock.com/mb/Intel/H110M-HDV/?cat=Specifications http://www.asrock.com/mb/Intel/H110M-HDV/?cat=Specifications
This is a limitation of the motherboard, not a limitation of the graphics controller.
Fred D.
