23787 Discussions
Intel HD Graphics Driver - Installation Failed
Intel HD Graphics Driver installation fails with the error:
"The setup program failed to start one or more application processes.
Setup will now exit."
This error occurs when it attempts to start the OCLSetup.exe during the installation.
I have run the installation both regularly and elevated as well as running it inside the built-in Windows administrator account.
Any help would be greatly appreciated.
OTHER_INFO
OS: Windows 8 Pro x64
CPU: Intel Core i7 3770K
HDD: Intel 520 Series SSD 120GB
MOBO: Gigabyte GA-Z77X-UD3H-WB WIFI Motherboard
CHIPSET: Intel Z77
NICHOLAS_F_Intel
Hi Jackson,
What driver version were you attempting to install?
Thank you,
-Nic
I tried:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22082&lang=eng Intel® HD Graphics Driver for Windows 7* and Windows 8* 64 (zip)
and
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22083&lang=eng Intel® HD Graphics Driver for Windows 7* and Windows 8* 64 (exe)
NICHOLAS_F_Intel
Thanks for the information Jackson. Are you able to successfully install the 2867 drivers (previous version) without issue? Also, have you tried installing the 2875 drivers from safe mode?
-Nic
Hi!
This work for my
1. Install OpenCL only
- Extract/Unpack/Unzip/etc. all files from the video driver installation package to
- Locate and execute OpenCL installation \OpenCL\OCLSetup.exe
- Follow instruction to finish.
2. Execute full video driver installation package.
Done!
ARao3
Thanks Dark, i know that this is a very old post.. But your solution worked like a charm..
