23526 Discussions
Bypassing DVI or HDMI Hot Plug detect pin
JSumm1
Hi all,
I have a system that can use up to 8 additional monitors (that is in addition the main video output) using a Quadro NVS card. This card has a DVI output and then we use a DVI to HDMI cable to drive up to 8 large monitors that are (could be) located in different areas. We have a custom software setup to direct different graphics to different screens that is pertinent to the area that each screen is in.
The problem we are having is if a monitor fails to be detected (due to any reason ... bad cable, monitor was turned off, monitor failed) then all of the information from that monitor and each one "up stream" of the failed monitors (as defined an our software) shifts to the next highest monitor and info that is supposed to be on the highest number monitor is not displayed at all. This obviously puts information on incorrect monitors.
What I would like to know is if if there is off the shelf hardware (either a HDMI cable, DVI cable, DVI to HDMI cable, or an adapter of any of those types) that has the hot plug pin jumpered (or connected in such a way) that even if there is no monitor connected the PC will detect that a monitor is connected.
Using an adapter would be my prefered way to do this. There may be a way to detect the loss of a monitor in SW and ignore it, but we have not been able to determine this as yet, and quite honestly dont want to modify our software and have to requalify/retest it to achieve this.
I suppose I can build my own if I have to, but I had much rather purchase something off the shefl that will do this.
JSUM
Allan_J_Intel1
Thanks for joining our community.
I was digging a bit on Internet and I found some information about this, it may be that you need a DVI hot plug detect spoofer, this was found on https://www.youtube.com/user/EEVblog https://www.youtube.com/user/EEVblog
Please bear in mind, Intel does not provide such graphics solution adapter.
Also, please take a look at this link below for more information:
http://philtechnicalblog.blogspot.com/2013/03/fixed-dvi-pin-16-hotplug-dilema.html http://philtechnicalblog.blogspot.com/2013/03/fixed-dvi-pin-16-hotplug-dilema.html
The content on these sites are not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered here.
Allan.
