23797 Discussions
Issues with Intel HD Graphics on a Pentium B950 Processor
TMcDo2
Hello there everyone, and thank you in advance for your assistance.
One week ago while playing War Thunder, a friend of mine suggested that I should update the drivers for my Intel HD Graphics card, as it would increase the frame rate of the game. I did exactly that and the effects were awesome. However, to my horror, I cannot seem to play half of the games I used to be able to! ArmA II: Operation Arrowhead, Left 4 Dead 2, Kerbal Space Program, and a multitude of others. The game will start up and once it does, the screen will go black and do nothing more, sounds continue to play in the background and everything functions, but it will not work. I can restart the computer, or even just put it to sleep with a keyboard command. When I do the latter, everything comes back as normal with whatever game at hand sitting on the "Start Bar", I have to close it out, otherwise the screen will black out again and I will be forced to put the laptop back into sleep mode. (Yes, I have tried Alt-Tabbing, Windows-Tabbing, and many other things.)
As a possible solution, I downloaded the earliest drivers I could get my hands on to see if I could solve the issue, however, the exact same thing happens. I still can play some games, which is strange, and for example, ArmA II: Operation Arrowhead will render in windowed mode, but whenever a game goes full screen it "kills" the screen.
Someone please help me!
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601)
System Manufacturer: Acer
System Model: Aspire 5750Z
BIOS: InsydeH2O Version V1.13
Processor: Intel(R) Pentium(R) CPU B950 @ 2.10GHz (2 CPUs), ~2.1GHz
Memory: 4096MB RAM
Page file: 1907MB used, 5986MB available
DirectX Version: DirectX 11
-Display-
Intel(R) HD Graphics
Chip Type: Intel(R) HD Graphics Family
DAC Type: Internal
Approx. total Memory: 1760MB
Driver Version: 9.17.10.3347
DDI Version: 10.1
Driver Model: WDDM 1.1
Through my searches I learned it was formerly known as the "Sandy Bridge"?
Allan_J_Intel1
Thanks for joining the community.
I am sorry to hear that you had issues when playing games after updating graphics drivers.
I would like to escalate this issue to our game team and see if this issue is related to the latest graphics drivers.
Please copy-paste or attach the Graphics report generated within the Intel(R) Graphics User Interface. To access this report, please click on Start >> Control Panel >>Intel GMA driver >> information >> Save To File...
http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
Also, I will need the DirectX report.
Click Start, click Run, type dxdiag in the Open box, and then click OK.
Allan.
TMcDo2
--- Intel HD Graphics Log ---
Report Date: 3/20/2014
Report Time[hh:mm:ss]: 17:57:34
Operating System: Microsoft Windows 7 Home Premium (6.1.7601)
Default Language: English (United States)
DirectX* Version: 11.0
Physical Memory: 3947 MB
Processor Speed: 2095 MHz
Vendor ID: 8086
Device ID: 0106
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics
Video BIOS: 2119.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 13.78 inches
Vertical: 07.48 inches
Monitor Supported Modes:
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 50 02 00 00 00 00
00 14 01 03 80 23 13 78 0A C2 D5 9C 60 55 9E 26
19 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 3E 1C 56 A0 50 00 16 30 30 20
35 00 59 C2 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 35 36 57 48 32 2D 54 4C 45 41 00 FD
* Other names and brands are the property of their respective owners. *
--- DxDiag ---
System Information
Time of this report: 3/20/2014, 17:57:40
Machine name: C-3PO
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
Memory: 4096MB RAM
Available OS Memory: 3948MB RAM
Page File: 1871MB used, 6021MB available
Windows Dir: C:\Windows
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0106&SUBSYS_05041025&REV_09
Display Memory: 1760 MB
Dedicated Memory: 128 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Model: unknown
Monitor Id: LGD0250
Native Mode: 1366 x 768(p) (59.973Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.3347 (English)
DDI Version: 10.1
Driver Attributes: Final Retail
Driver Date/Size: 10/31/2013 10:28:30, 12617216 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4246-11CF-867E-0E25B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0106
SubSys ID: 0x05041025
Revision ID: 0x0009
Driver Strong Name: oem80.inf:Intel.Mfg.NTamd64:iSNBM0:9.17.10.3347:pci\ven_8086&dev_0106
Rank Of Driver: 00DE2001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
TMcDo2
Aha! I have found the correct driver to fix my problem, temporarily if nothing more! This driver, version 8.15.10.2342 works for the Acer Aspire 5750Z, if anyone else is having problems with theirs! http://global-download.acer.com/GDFiles/Driver/VGA/VGA_Intel_8.15.10.2342_W7x86W7x64_A.zip?acerid=634761931954606771&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%205750Z&OS=ALL&LC=en&BC=ACER&SC=PA_6 Here is the link!
None the less, thank you very much for your help, and I hope this post finds its way to someone else who needs help with this issue! Game on!
