23851 Discussions
Intel HD Graphics and HDMI problem!
I have Gigabyte GA-Z68AP-D3 and Core i3 2100. Windows 7 x64. When i use pci-e video all work fine, but when using hdmi output and integrated CPU graphics, black screen and computer freeze until restart. BTW with 2219 driver no textures or black textures in many games. No solution yet?
NICHOLAS_F_Intel
In order to assist you, I need confirmation that you have tested both of the following drivers:
http://www.gigabyte.com/products/product-page.aspx?pid=3897# dl Gigabyte provided 15.28.4.2843
and our latest driver 15.28.8.2875
We need to know that you have tried both of those drivers, and are still experiencing the exact same issues. The issue as you have presented it, is that you cannot see a display over HDMI connection to your screen after installing these specific drivers.
-Nic
Dear friend, with that both drivers system can not start.
Any news about?
aelbo
i got the same problem "HDMI not work on my laptop (intel HD graphics)
i had bought a laptop 'hp 630' windows 7 edition ultimate 2 years ago
so when i tried to connect(just about 2 weeks) HDMI i found that my HD tv don't recognize HDMI input and my computer can detect the tv but he can't costomize it i tried to up-date and "down-date" the driver but the problem still the same and olso my computer recognize my tv just if i remove and re-install the driver when my computer is already connected to the tv by 'HDMI'
and when i click on detect on Control Panel\All Control Panel Items\Display\Screen Resolution i get anoter monitor with this msg "another display not detected " " avalaible display output on :
intel (r) HD graphics check pic
i tried to give you all info about my computer blow and thanks in advance "and sorry for my english"
if you needmore info so iam glade to give it to you
=================info===================
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 😎
Number of threads 4 (max 16)
Name Intel Core i3 370M
Codename Arrandale
Specification Intel(R) Core(TM) i3 CPU M 370 @ 2.40GHz
Package (platform ID) Socket 989 rPGA (0x4)
CPUID 6.5.5
Extended CPUID 6.25
Core Stepping K0
Technology 32 nm
TDP Limit 25 Watts
Core Speed 931.2 MHz
Multiplier x Bus Speed 7.0 x 133.0 MHz
Rated Bus speed 2394.5 MHz
Stock frequency 2400 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 4-way set associative, 64-byte line size
L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 3 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Chipset
Northbridge Intel Havendale/Clarkdale Host Bridge rev. 02
Southbridge Intel HM55 rev. 05
Memory Type DDR3
Memory Size 2 GBytes
Channels Single
Memory Frequency 532.1 MHz (4:16)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Row Refresh Cycle Time (tRFC) 86
Command Rate (CR) 1T
MCHBAR I/O Base address 0x0FED10000
MCHBAR I/O Size 4096
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format SO-DIMM
Manufacturer (ID) Samsung (CE00000000000000)
Size 2048 MBytes
Max bandwidth PC3-10700 (667 MHz)
Software
Windows Version Microsoft Windows 7 (6.1) Ultimate Edition 32-bit Service Pack 1 (Build 7601)
DirectX Version 11.0
Display Adapters
Display adapter 0
Display name \\.\DISPLAY4
Name Intel(R) HD Graphics
Memory size 730 MB
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x103C)
Model ID 0x0046 (0x3674)
Performance Level 0
Win32_VideoController AdapterRAM = 0x2DAED800 (766433280)
Win32_VideoController DriverVersion = 8.15.10.2993
Win32_VideoController DriverDate = 01/30/2013
