- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
When selecting 23Hz or 24Hz; they both give me 23.976Hz.
I've tried to set up a custom resolution on 24Hz (3840x2160), that works perfect, but now the 23hz (23.976) is overwritten by the new custom setting in addition to the new 24Hz. So creating a custom 3840x2160@24Hz gives me 24.000Hz on both 23Hz and 24Hz selection.
I want to have 23Hz selection to be 23.976Hz, and 24Hz to be 24.000Hz. How can this be done?
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello TGBerland,
Thank you for joining the Intel communities.
What is that you are trying to accomplish with this?
Please reply with your graphics report:
Go to Intel® Graphics and Control Panel > Options > information Center > Save.
Or you can check the following link to get the report:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html Intel® Graphics Driver Report for Graphics Drivers
Also, I will appreciate if you can post the msinfo32.
- Please press Windows Key + R to open the Run Menu
- Type msinfo32 and click OK
- While viewing the System Summary node go to File then Save (Please do not use Export)
- Save your MSINFO32 report as msinfo32.nfo on your desktop for easy access and then you can post it here
Ivan
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
My goal is the view 23.976 FPS source in 23.976Hz, and to view 24.000FPS in 24.000Hz to avoid framedrop and get smooth playback.
Intel(R) Iris(TM) Graphics 5100
Rapportdato: 4. februar 2016
Rapporttidspunkt [tt:mm:ss]: 20:34:28
Driverversjon: 20.19.15.4300
Operativsystem: Windows* 10 Pro(10.0.10240)
Standardspråk: Norwegian Bokmål (Norway)
Fysisk minne: 8068 MB
Leverandør-ID: 8086
Enhets-ID: 0A2E
Enhetsutgave: 09
Grafikk-BIOS: 1215.0
Nåværende oppløsning: 3840 x 2160
Prosessor: Intel(R) Core(TM) i5-4308U CPU @ 2.80GHz
Prosessorhastighet: 2800 MHz
Prosessorgrafikk i bruk: Intel(R) Iris(TM) Graphics 5100
Shader-versjon: 5.0
OpenGL*-versjon: 4.3
OpenCL*-versjon: 1.2
* Microsoft DirectX* *
Kjøretidsversjon: 12.0
Maskinvarestøttet versjon: 11.1
* Enheter koblet til grafikkakseleratoren *
Aktive skjermer: 1
* Digital TV *
Skjermtype: Digital
DDC2-protokoll: Støttes
Gamma: 2,2
Tilkoblingstype: DisplayPort
Enhetstype: Digital TV
Største bildestørrelse
Horisontal størrelse: 40,16 tommer
Vertikal størrelse: 22,44 tommer
Støttede modi
640 x 480 (60p Hz)
640 x 480 (67p Hz)
640 x 480 (72p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 576 (50p Hz)
720 x 480 (60p Hz)
720 x 576 (50i Hz)
720 x 480 (60i Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1024 x 768 (70p Hz)
1152 x 864 (75p Hz)
1152 x 870 (75p Hz)
1280 x 1024 (60p Hz)
1280 x 1024 (75p Hz)
1280 x 720 (60p Hz)
1280 x 800 (60p Hz)
1280 x 720 (50p Hz)
1440 x 480 (60p Hz)
1440 x 576 (50p Hz)
1440 x 900 (60p Hz)
1600 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (24p Hz)
1920 x 1080 (25p Hz)
1920 x 1080 (30p Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (60p Hz)
1920 x 1080 (60i Hz)
2880 x 480 (60p Hz)
2880 x 576 (50p Hz)
3840 x 2160 (24p Hz)
3840 x 2160 (30p Hz)
3840 x 2160 (25p Hz)
4096 x 2160 (24p Hz)
Rå-EDID:
00 FF FF FF FF FF FF 00 35 49 32 00 01 01 01 01
00 19 01 03 80 66 39 78 0A 23 AD A4 54 4D 99 26
0F 47 4A BD EF 80 71 4F 81 C0 81 00 81 80 95 00
A9 C0 B3 00 01 01 04 74 00 30 F2 70 5A 80 B0 58
8A 00 50 1D 74 00 00 1E 02 3A 80 18 71 38 2D 40
58 2C 45 00 50 1D 74 00 00 1E 00 00 00 FC 00 6D
61 72 61 6E 74 7A 2D 41 56 52 0A 20 00 00 00 FD
00 18 4B 0F 51 1E 00 0A 20 20 20 20 20 20 01 B5
02 03 5A F1 57 5F 10 1F 04 13 05 14 20 21 22 5D
5E 62 63 64 07 16 03 12 0F 24 1E 26 35 0F 7F 07
15 07 50 3D 1E C0 4D 02 00 57 06 01 5F 7E 03 67
7E 01 83 5F 00 00 76 03 0C 00 45 00 B8 3C 21 D0
88 01 02 03 04 01 40 0F FF 50 60 80 90 E2 00 0F
E5 0E 60 61 65 66 E3 06 05 01 01 1D 80 D0 72 1C
16 20 10 2C 25 80 50 1D 74 00 00 9E 02 3A 80 18
71 38 2D 40 58 2C 45 00 C4 8E 21 00 00 1E 00 80
* Andre navn og merker eies av sine respektive eiere.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
The TV is Samsung UE78JS9505 (Nordic edition of UE78JS9500; tuner is the difference). I know this screen supports both 23.976Hz and 24.000Hz. Running computer in OS X give me perfect 24.000Hz by the way, but OS X is not capable of transmitting binary TrueHD and DTS-HD.MA via HDMI, and besides it does not support 23.976Hz (which most US/UK blu-rays are released with). Most movies produced in the nordic countries are for some reason usually released in 24.000Hz. That is why I need both
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I'm sorry I'm a little confused, so your issue has been resolved or you still have the problem?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Still not solved; not sure why the resolved part got tagged her. I can get either 23.976Hz or 24.000Hz; not both - still an issue.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Can I suggest a more practical workaround OP?
If you install MPC-HC, and use SyncRenderer and reclock, you can playback 23.976fps video at 24.0hz, and have the system reclock the audio.
I've found it a worthy compromise for the time being.
Phil
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Currently I reclock the video so I play back 24.000Hz@23.976; since most bluray movies are 23.976 I found this to be the best compromise. But I really want to have both options available without reclocking the video.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Unfortunately this is not possible with the Intel driver, maybe in the future could be add it to the driver or it will be a way to do it but the driver right now has been built as it is.
Honestly I don't see the way to do that with the Intel driver.
Best wishes,
Ivan
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
But that indicates you have a driver that does not solve the customers requirements; a lot of people are using intel hd-graphics for media computers. This is a common problem that should be solved. Even Nvidia and AMD got a solution for this.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
This is a pretty serious issue and basically renders his media centre useless. He is better off with a 3 year old AMD machine unless the driver is fixed.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Please allow me to further investigate on this.
Before doing any further investigation could you please try the https://downloadcenter.intel.com/download/25860/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81494 driver version 15.40.18.4380
Ivan
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
TGBerland All I can suggest is to use linux for your HTPC.
I've been using Kodi on Arch linux and the refresh rates have been flawless - 23.976 and 24.00.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
