23854 Discussions
Intel HD Windows 8 DXVA2 artifacts
DStep3
Hello, im trying to make my celeron g530 to play blyray movies with low CPU load, so I used VLC player and MPC-HC, enabled DXVA2(EVR custom for MPC, enable video acceleration for VLC). And what a surprize! I got nice artifacts on video:
my driver(its latest, tried older versions - all give same artifacts):
When I disable DXVA2, it plays without artifacts, also I have absolutely no problems in other apps.
How can I fix it - I need DXVA2 ^_^!
I think it worked before, but broken now. If I reinstalled 3 drivers and got same artifacts in 2 different players, is it hardware issue?
My motherboard is ECS H61-I2 rev.1.0. But I guess it's cpu internal graphics/OS(hmm) issue.
I have Windows 8 Pro, fully activated and licensed but I cant reinstall it, because im using "free" Media Center key(which can be activated only once, I have previous serial which I bought from MS).
dxdiag:
System Information
Time of this report: 6/25/2013, 00:29:19
Machine name: NOANGELD2
Operating System: Windows 8 Pro with Media Center 64-bit (6.2, Build 9200) (9200.win8_gdr.130410-1505)
Language: Japanese (Regional Setting: Japanese)
System Manufacturer: ECS
System Model: H61H2-I2
BIOS: 4.6.5
Processor: Intel(R) Celeron(R) CPU G530 @ 2.40GHz (2 CPUs), ~2.4GHz
Memory: 4096MB RAM
Available OS Memory: 3910MB RAM
Page File: 1570MB used, 2436MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0102&SUBSYS_31421019&REV_09
Display Memory: 1760 MB
Dedicated Memory: 128 MB
Shared Memory: 1632 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: AOC 2757M
Monitor Model: 2757
Monitor Id: AOC2757
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.3062 (English)
Driver Version: 9.17.10.3062
DDI Version: 10.1
Feature Levels: 10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Driver Attributes: Final Retail
Driver Date/Size: 3/9/2013 11:10:17, 12615680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4242-11CF-5F78-4811B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0102
SubSys ID: 0x31421019
Revision ID: 0x0009
Driver Strong Name: oem2.inf:5f63e534c036a854:iSNBD0:9.17.10.3062:pci\ven_8086&dev_0102
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2...
DStep3
vlc 2.0.7 screenshot:
DStep3
Also I tried intel hd driver from ECS support page - same artifacts.
My motherboard BIOS is latest available
Kevin_M_Intel
Hello NoAngel,
It seems you have tried several troubleshooting that I was going to advise you to do; however, there is something else I would like you to try and it is to update the codec's in your computer and if possible test another player so we can discard any possible hardware issue.
I see you have installed the latest driver we have from our side. In the case the issue persists after updating the codec's, I recommend you installing the driver available from MSI (system manufacturer) for your computer.
DStep3
Thank You, Kevin!!! I got it, that was buggy codec from ffmpeg.
When I disabled MPC-HC internal H.264/AVC codec it used external Microsoft DTV-DVD Video Decoder (Msmpeg2vdec.dll), Blu-ray video played ideally, without artifacts, very smooth, and only 5% CPU load.
As for video driver, I'll stay with build 3062 - it works faster, than MS default Windows 8 one, in 2D.
Problem solved!
Dmitry Stepanushkin
VSoku
Hello, could you please be so kind and tell me how did you fix the issue ? My vlc media player still has artifacts and I don't understand how to disable MPC-HC and install Microsoft DTV-DVD Video Decoder ?
