22649 토론
Intel HD driver fails on W10 Creators release - Insprion 660
SPalm2
초보자
11,615 조회수
I was asked to re-post this in a new thread
Intel HD Graphics Properties reports Windows has stopped this device because it has reported problems (Code 43).
Faulting application name: dwm.exe, version: 10.0.15063.0, time stamp: 0x982d0cc7
Faulting module name: igd10iumd64.dll, version: 10.18.10.4653, time stamp: 0x58e7c06c
Exception code: 0xc0000005
Fault offset: 0x000000000019a4a3
Faulting process id: 0x11f4
Faulting application start time: 0x01d3739979adbec0
Faulting application path: C:\WINDOWS\system32\dwm.exe
Faulting module path: C:\WINDOWS\system32\igd10iumd64.dll
Report Id: 43469d3f-b9d1-46b9-b4c6-26fd75a4012c
Faulting package full name:
Faulting package-relative application ID:
Dell Inspiron 660
Windows 10 Pro
Intel i3-3240 3.40 Ghz
Dell 478VN Motherboard
Intel B75 Chipset
Intel HD Graphics
8GB Memory
The PC and Intel HD Graphics driver have worked flawlessly under Windows 10 Pro up until the installation of Microsoft's Windows 10 Creators update. I first saw this with a recent push of the spring version of the Creators update. I tried manually adding in the fall version. Same results.
After the driver fails to load, Windows 10 reverts to Basic mode.
In basic mode, I cannot run dual monitors (VGA and HDMI) simultaneously.
I have run Dell's update utility and Intel's update utility - everything is up to date.
I have tried pretty much everything suggested in similar threads.
I can unrolled the Windows 10 Creators update and the driver functions without issue.
I have seen where others have reported similar problems with different flavors of HD Graphics HW (3000,4000,5000)
My device properties shows my HW as "HD Graphics" with no series indicated.
28 응답
SPalm2
초보자
2,490 조회수
Just unbelievable!
Your driver crashes and it's somebody else's fault.
When your driver crashes, it's your fault. Period. No-one else's.
And way before submitting the initial info in this thread, I had removed the HDMI/USB device to see if that made a difference.
It did not.
I remind you your driver and the HDMI/USB device worked before the Creator's update.
And after the Creators update, the HDMI/USB device continues to function and Windows does not blue-screen.
YOUR driver fails.
0 포인트
Alberto_Sykes
직원
2,490 조회수
vaguy: Thank you for letting us know those updates. We will do further research on this matter, as soon as I get any details I will post all the information on the thread.
Alberto R
0 포인트
DSuvo
초급자
2,490 조회수
Similar issue tracked here:
0 포인트
Alberto_Sykes
직원
2,490 조회수
vaguy: I just received and update on this matter, the driver has been tested with RS3 and works fine for us and many other customers. Some have faced the issue with error 43 after the update is done, thus suggesting a potential issue with the Operating System upgrade process. Please try a clean RS3 installation if you have the option to do that.
If the problem persists, then the next thing to do will be to get in contact directly with Dell for further assistance, you can always provide them with the link of the thread so they can see that Intel has validated the driver for RS3 already.
Alberto R
0 포인트
SPalm2
초보자
2,490 조회수
A clean RS3 is really not an option form me.
A validated driver for RS3 means nothing to me. A driver that stays running does.
You state that some have faced the issue with error 43 after the update is done.
Well, duh, that is why I started this thread.
But you don't state that a clean install will resolved this issue.
You are shooting from the hip.
Please provide source code to driver for me to investigate.
At a minimum tell me precisely under what circumstance (given all of the debug information I provided to you) that your driver would return a Code 43
0 포인트
DSuvo
초급자
2,490 조회수
Hi Vaguy,
This is dwm.exe crash. Thanks to Stephen3D, I've got some direction on collecting more detailed debug info. You need to collect the dwm.exe crash dump (https://blogs.msdn.microsoft.com/chaun/2013/11/12/steps-to-catch-a-simple-crash-dump-of-a-crashing-process/ Steps to Catch a Simple "Crash Dump" of a Crashing Process – Share Poignant ) and use windbg to fetch the stack trace.
This may shed some light on the circumstances.
0 포인트
SPalm2
초보자
2,490 조회수
Excellent suggestion. I followed Stephen3D's instructions and saw that a component of my StarTech USB-HDMI driver was in the stack (even thought I disabled the device).
I checked with Startech and found they had updated their driver for RS3. Interestingly, the StarTech pre-RS3 driver did work under RS3 (as far as the HDMI monitor that was plugged into the Startech's dongle was concerned), but it caused havoc with the Intel driver shutting down.
The key to this solution was you mentioning that dwm.exe was crashing. I had been operating under the assumption that a component of the Intel driver was crashing.
0 포인트
AlbertoR_Intel
2,490 조회수
vaguy: Thank you for providing those results. We will continue with our research on this matter and we will let you know about any updates as soon as possible.
Alberto R
0 포인트
응답
