22968 Discussions
Intel HD graphics can't output HDMI signal on my Samsung monitor SA350
AKhan27
hello,
Gigabyte motherboard : B85M-D3H
Processor: Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz (4 CPUs), ~3.0GHz
Memory: 4096MB RAM
DirectX Version: DirectX 11
My HDMI worked fine for months and then it suddenly stopped after an update,
i tried all the method mentioned in the forum but it didn't worked. i connect my laptop
to my Samsung SA350 monitor and it worked fine but my PC HDMIhas never worked since then.
I taught the PC as the issue so i connected my PC to my TV , it works fine. Please help me.
Allan_J_Intel1
Hi Kabir96,
What is the operating system version?
I will also need information if your operating system is 32 bit or 64 bit.
Make sure you are using hdmi to hdmi cables because the usage of video adapters will prevent this feature from working correctly.
Allan
AKhan27
Hello Allan , thank you for your reply .
I am using windows 7 ultimate service pack 1 . 64 bit . I am using HDMI to HDMI cable .
AKhan27
AKhan27
Hello Allan , I uninstall the driver and installed it again from the zip . Still the HDMI was not working so I went to the intel hd graphic control panel and since my monitor has a VGA port and an HDMI port so I have a monitor and a digital monitor listed so I selected the digital monitor and lowered the resolution to 1024* 768 and the HDMI worked . So i used the setting and selected only digital monitor and removed the VGA and it's working now , when I reboot the computer the monitor displays nothing till the windows started , it didn't displays the bios menu and it was blank . I got HDMI to work but the resolution is too large so I have to still use VGA .
Please help me ,
Thank you soo much Allan .
Allan_J_Intel1
Hi Kabir96,
At this stage, let's wait for new driver releases, I do not an estimate for new drivers but I hope this will be fixed on the next drivers. Or you can check with your motherboard maker for any customized drivers for your motherboard model.
Allan.
AKhan27
Okay , thanks for trying ,
What I don't understand is that ,first it was working fine and after the update it's not working . I did a bios update and reinstalled the entire operating system from the start and still it's not working . I taught formatting the hard drive would delete everything and it will be like my old system . When I bought the new processor and motherboard it was working and now it's not working , why ??
Allan_J_Intel1
You probably need to load the drivers that came with the computer or motherboard off the installation DVD. Also update BIOS of the computer, this will interact with graphics VBIOS.
Please check for original video drivers and BIOS update from your motherboard maker.
