22965 Discussions
Intel HD4600 cannot set custom resolution of 2560x1600 - bandwitdh capacity exceeded!
KOoi2
Hi some professional out there, I need advise... I tried this:
using my laptop dell E6440 having Intel HD4600 graphic, tried to dock on an E-port replicator PR02X or PR03X , then connecting the external monitor thru of Dell 3007WFP thru DisplayPort at E-port replicator (converter from DP to DVI-Dual Link is Dell DANARBC084). As there's no option to choose for 2560x1600 resolution, so I need to create one custom resolution. I open the Intel HD Graphics Control Panel, and key-in my needed resolution 2560x1600@60Hz, it says "The custom resolution exceeds the maximum bandwidth capacity". Without the resolution, my monitor can only display 1280x800. I really need the resolution. Below is the information center report, hope someone may help to advise, many thanks!
Intel(R) HD Graphics 4600
Report Date: 6/10/2015
Report Time[hh:mm:ss]: 22:49:08
Driver Version: 9.18.10.3204
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: English (Malaysia)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
Physical Memory: 8097 MB
Processor: Intel(R) Core(TM) i5-4210M CPU @ 2.60GHz
Processor Speed: 2594 MHz
Vendor ID: 8086
Device ID: 0416
Device Revision: 06
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4600
Video BIOS: 2178.15
Current Graphics Mode: 1600 by 900
* Devices Connected to the Graphics Accelerator *
Active Digital Displays: 1
Active Notebook Displays: 1
* Digital Display *
Monitor Name: Dell 3007WFP
Display Type: Digital
Connector Type: DisplayPort
Serial Number: DEL4016
Gamma: 2.2
DDC2 Protocol: Supported
Device Type: Digital Display
Maximum Image Size:
Horizontal: 25.20 inches
Vertical: 15.75 inches
Monitor Supported Modes:
1280 by 800 (60 Hz)
2560 by 1600 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC 16 40 38 30 30 47
1A 10 01 03 80 40 28 78 28 FE 87 A3 57 4A 9C 25
13 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 BC 1B 00 A0 50 20 17 30 30 20
36 00 86 96 21 00 00 1A B0 68 00 A0 A0 40 2E 60
30 20 36 00 86 96 21 00 00 1E 00 00 00 FC 00 44
45 4C 4C 20 33 30 30 37 57 46 50 0A 00 00 00 FF
00 46 4B 32 38 35 36 37 31 47 30 30 38 0A 00 48
* Built-in Display *
Monitor Name: Generic PnP Monitor
Connector Type: Embedded DisplayPort
Serial Number: SDC544B
Gamma: 2.2
Device Type: Built-in Display
Maximum Image Size:
Horizontal: 12.20 inches
Vertical: 06.69 inches
1600 by 900 (36 Hz)
1600 by 900 (60 Hz)
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4C 83 4B 54 00 00 00 00
00 16 01 04 90 1F 11 78 0A 76 15 95 5B 57 90 2A
21 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 8C 2C 40 80 61 84 3A 30 30 20
25 00 35 AE 10 00 00 1A 07 1B 40 80 61 84 3A 30
30 20 25 00 35 AE 10 00 00 1A 00 00 00 FE 00 35
59 30 44 37 80 31 34 30 4B 54 0A 20 00 00 00 00
00 00 41 21 94 01 10 00 00 01 01 0A 20 20 00 76
* Other names and brands are the property of their respective owners. *
Hans_B_Intel
Hi KhongHeng,
I am sorry you are having problems setting the resolution but let me help you.
My first advice is to update the graphics driver. Here you have the download link to get the 15.36.21.4222 version that has been posted to Intel Download Center at the following direct links to the drivers:
32bit - http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24965 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24965
64 bit - http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24964 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24964
If you have problems during the installation of the driver, you can follow the steps mentioned here:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Besides updating the graphics driver, another good step is to update the BIOS in your system.
Hans_B_Intel
Hi KhongHeng
Also I would like to add some extra points to consider:
1) Be aware that these are generic drivers with no specific OEM customizations. If your system is a laptop or tablet based system it likely has customizations to the driver made by the manufacturer of the system. If you install the generic driver you will lose the customizations and the system may not work as intended. If it is a laptop or tablet recommend you use the latest drivers supplied by the manufacturer.
If you want to try the generic driver I would recommend you set a restore point before updating the driver. Download the zip version of the drive and extract to a folder on your desktop.To install the generic driver, follow these steps exactly.
  1. 1. Login with administrator privileges
  2. 2. Open Control Panel
  3. 3. Open Device Manager
  4. 4. Click on "Display adapters"
  5. 5. Double click "Intel HD Graphics"
  6. 6. Click on the "Driver" tab
  7. 7. Click on "Update Driver" button
  8. 8. Click on "Browse my computer for driver software"
  9. 9. Click on "Let me pick from a list of device drivers on my computer"
  10. 10. Click on "Have Disk" button
  11. 11. Click "Browse"
  12. 12. Navigate to the folder that you unzipped the Intel HD Graphics driver to
  13. 13. Navigate to the Graphics sub-folder
  14. 14. Double click the igdlh64.inf or igdlh.inf file <-- depends on if you have 32 or 64 bit OS</span>
  15. 15. Click "OK"
  16. 16. Click "Next", Driver should now be installing.
  17. 17. If successful, click "Close", Reboot.
2) Please note that Intel HD Graphics driver does not support Dual Link DVI. It only supports single link.
JEFFREY_F_Intel
Intel graphics doesn't support DVI dual link. As a result you will either be limited to lower resolution (19x12 @60Hz) or perhaps, if your monitor supports it, 25x16 at lower refresh rate (say 30Hz).
Intel graphics supports mailto:25x16@60Hz 25x16@60Hz no problem via HDMI and DP is you don't convert to DVI... Can you run HDMI 1.4 or DP1.2 from replicator to the monitor?
KOoi2
Hi all,
I finally found the solution - Dell E6440 + Eport Replicator + "Dell DisplayPort to DVI Adapter DANASBC084 KDP70".
I bought the Adapter thru Ebay (also available in Amazon). Once it's attached to the eport replicator DisplayPort, with my Monitor 3007WFP, my laptop automatically detects and show the option of 2560x1600 (60Hz).
Thanks hansb_intel for the suggestion.
Thanks rootheday for replaying. My monitor only support 25x16 (60hz) or 12x80 (60Hz)... I tried HDMI but in vain. My monitor has only dvi-dual link, no other option/port.
Now it's done, but the display is somehow a bit noisy, I am not sure if that's the cable issue. Anyway, thanks everyone trying to help.
