23833 Discussions
Intel HUD 770 and Radeon RX 570 have the OpenGL problem
yuchen230
When both Intel and AMD graphics cards are enabled, an error will be reported: openg1.1. When I disable amd graphics card and only enable Intel graphics card, there will be no error. When amd graphics card is enabled and Intel graphics card is disabled, an error is still reported. I think what should I do if both graphics cards are enabled
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
