23061 Discussions
Intel IRIS 655 NUC8I3BEH and 144Hz
arkglad
Can the IRIS 655 do 144Hz on 1920*1080 and 1440p with HDMI 2.0a ?
And can i put an SSD sata 2.5" on the nuc 813beh ?
Thank you
LeonWaksman
1. 144Hz on 1920*1080 requires Data rate of 8Gbits/s, since the HDMI in this NUC supports standard 2.0a (4K at 60Hz 12.54 Gbit/s), it should work for you. You should use high quality video cable.
2. Yes, you can install 2.5" SSD in NUC8i3BEH. See list of SSD drives validated by Intel/Manufacturer for this NUC.
Leon
