22946 Discussions
Intel Iris 540 vs Intel HD 520: which Graphic card is compatible with 1280x800 resolution?
lluca4
Hi all,
I'm going to buy a new Intel Nuc 6 and I was wondering which is better or this purpose: I have to use a 1280x800 resolution, so I have to choose between the intel Nuc 6i3 with HD 520 graphic and the intel nuc 6i5 with iris 540.
I've searched for these 2 graphic card but I didn't find complete list of all the resolutions supported...since I've already tried a Nuc 5i3 that I have and it doesn't display well at this resolution, I ask you if it is possible to have a certified list of all the resolutions supported and if someone has already tested it.
thank you
Luca
Hi lupoz91,
The 6i5SYK comes with HD Iris™ 540 and 6i3SYK comes with HD 520. Both support the same maximum resolution of:
HDMI 1.4b: 4096x2304@24Hz
miniDP1.2: 4096x2304@60Hz
eDP1.2: 4096x2304@60Hz
The link below compares both processors
http://ark.intel.com/compare/91160,88180 http://ark.intel.com/compare/91160,88180
All the 6th gen NUCs are capable to support 1280x800 resolutions.
Mike C
Hi lupoz91,
Mike C
lluca4
Thanks MIke,
I'm asking since I have a Intel NUC 5i3RYH and we have some problem setting 1280x800 resolution.
5th series also supports officially the 1280x800 resolution?
Hi lupoz91,
The 5th gen NUCs supports the maximum resolutions
HDMI 1.4a: 2560x1600@60Hz
DP: 3840x2160@60Hz
Now, it is possible to decrease the resolution if the TV or Monitor supports it.
Mike C
