19556 Discussions
Intel® Iris(R) Xe Graphics  match win10  in USBC Port  DDCCI Connect Fail ,HDMI Success.
humbleZheng
help:
Intel® Iris(R) Xe Graphics  Connect to Monitor Fail by intelSDK driver interface(IGFX_GET_SET_BUS_INFO_GUID)
USBC Port:Fail
HDMI Port:Success
Can it be repaired ?
Alberto_R_Intel
humbleZheng, Thank you for posting in the Intel® Communities Support.
Just to let you know, in order for us to be able to provide the most accurate support on this matter, I just moved your thread to the proper department, they will provide further assistance on this scenario as soon as possible.
Albert R.
AlekhyaV_Intel
Thank you for posting in Intel Communities. We're investigating this issue internally. We will get back to you soon with an update.
Alekhya
Alberto_R_Intel
humbleZheng, I just received an update on this matter.
While we are reviewing your case, we just wanted to confirm:
What is the procedure or process that you are doing or attempting to do that shows the error?
What is the hardware and software required to reproduce the issue?
Is the issue only visible on new drivers?
When switching to an older driver is the problem the same? Please provide the specific version of the drivers that show the issue.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Alberto_R_Intel
Hello humbleZheng, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello humbleZheng, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
