23796 Discussions
Intel Iris Xe Graphics Issue
gummy21
hi! i just bought an ASUS k413ea with intel iris xe graphics and 11th gen i5. It's still 1 day old, but it already show a  problem, my screen keeps flickering. When i set the brightness to the lowest, the flickers clearly visible and it annoys me a lot. I've tried to update all the drivers but nothing changed. So how can i fix this?
David_G_Intel
Hello gummy21
Thank you for posting on the Intel️® communities.
Please share with us a video of the problem and the results of the Intel® System Support Utility (Intel® SSU)
  • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
  • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
Also, please provide the following information:
  • Drivers versions tested
  • Did you try the drivers from the OEM?
  • Does this happen with a second screen?
  • If you use the Microsoft Basic Display Adapter, do you see the same problem?
David G
Intel Customer Support Technician
Alberto_Sykes
Hello gummy21, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
David_G_Intel
Hello gummy21
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Best regards,
David G.
