22680 ディスカッション
Intel Iris Xe "No Signal" after installing driver on Mini-PC
GuyB
ビギナー
1,435件の閲覧回数
I just received a new MINI PC (NUC Type) - Morefine M9 Pro i5-1340p that I loaded with windows 11 Pro 23H2. Everything installed properly and all the drivers provided by the manufacturer updated accordingly except for the Intel Iris Xe graphic display.
The only way Windows 11 displays my screen is when the basic Microsoft Display drivers are installed. When I try to update to The Iris Xe drivers my monitor turns black and display no signal.
The PC runs under 16GB DDR4 RAM (2 x 8GB) dual channel memory
512GG SSPC PCIe SSD... without any junk added ...yet.
I tried to install the new graphic drivers using 2 different monitors and a multitude of different HDMI cables to be sure they weren't the cause of my problem... No luck I always get the same "no signal" message after installing the drivers.
I tried the older drivers provideds with the PC and even tried the latest release (clean install) after running the Intel Support  & drivers software with the same result.
Any solution to that problem?  Microsoft basic display drivere is of no use for me.
0 件の賞賛
3 返答(返信)
IsaacQ_Intel
従業員
1,396件の閲覧回数
Hello @GuyB
1.      Have you checked the manufacturer's website or support forums for any known issues or specific instructions related to installing Intel Iris Xe graphics drivers on your Morefine M9 Pro i5-1340p with Windows 11 Pro 23H2?
2.      Can you provide details about the specific error messages or codes, if any, that you encounter when the monitor goes black after installing the Intel Iris Xe drivers?
3.      Have you attempted to contact Morefine's customer support for assistance with this issue, and if so, what guidance or solutions have they provided?
4.      Are there any BIOS or firmware updates available for your MINI PC, and if yes, have you considered updating them to see if it resolves the problem with Intel Iris Xe graphics?
5.      Have you tried adjusting any display settings within the Windows 11 operating system after installing the Intel Iris Xe drivers, such as resolution or refresh rate, to see if that has any impact on the "no signal" issue?
Please consider following the troubleshooting steps provided in this article:
How to Resolve Issue with Black Screen While Using the System with Integrated Graphics.
Isaac Q.
IsaacQ_Intel
従業員
1,359件の閲覧回数
Hello GuyB,
We hope you are doing fine.
Please answer my questions, and let me know if the article helped you to resolve the issue.
Isaac Q.
DeividA_Intel
従業員
1,332件の閲覧回数
Hello GuyB,
I was checking your thread and noticed that I have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
返信
