23806 Discussions
Intel Matrix Storage Manager caused corrupt disk
I just notice that if you set your virtual memory to the recomended size or w/e on a different partition instead of main drive (C drive), and you install matrix storage on a newly installed Vista or Windows 7 either x86 or x64 it will cause OS to show "corrupted disk" message (not sure if this happen to people who install matrix storage 1st be4 setting virtual memory on a different partition). After it shows that you can't install anything on the OS or update it, so basically you have to reinstall the whole OS. I use Matrix 8.8.0.1009 on Vista 64x and for Windows x86 i just downloaded the latest version from the update.
I forgot to mention I have GM965 chipset.
i mean Windows 7 X86** not Windows x86
