23586 Discussions
Intel® Quick Sync Video H.264 Encoder MFT what should be the input and output samples
vicsfdasfsffda
Intel arc 770
I tried using async mft in the normal way which works for nvidia, amd and legacy intel mft
When I try to add a texture-based built on an nv12 or argb texture to the processinput, I get an access violation.
If using a texture with multiple subresources, processinput always returns s_ok but the METransformHaveOutput event never fires.
What should be the input and output samples.
IsaacQ_Intel
Hello @vicsfdasfsffda
·        Please provide us a screenshot of the issue.
·        What settings were used to reproduce the issue?
·        Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
·        Please provide us with the Operating system version and Bios version.
Isaac Q.
vicsfdasfsffda
This is a simple question that can be easily answered by someone who knows the answer. I can't take screenshots of mft.
IsaacQ_Intel
Hello @ Vicsfdasfsffda
Thank you for your reply.
We apologize for the inconvenience.
We will proceed to check the issue internally and post back soon with more details.
Isaac Q.
IsaacQ_Intel
Thank you for your patience.
We suggest contacting the developer's forum to get better support regarding this issue. Complex technical questions, coding challenges, and development-related inquiries are often better suited for discussion on dedicated developer's forum and communities.
Please consider posting your inquiry on the correct forum.
If you want to continue with this thread, we would like to know if you are using Intel Media SDK? and Which framework are you using?
Otherwise, let us know so we will close the case.
Isaac Q.
vicsfdasfsffda
I use media foundation transforms  in winapi. Last intel drivers and updated windows 10.
IsaacQ_Intel
We appreciate the information provided.
According to our team in charge, it will be better, to contact the developer's forum. Complex technical questions, coding challenges, and development-related inquiries are often better suited for discussion on dedicated developer forums communities.
Isaac Q.
vicsfdasfsffda
So intel can't provide code example for mft for 10 years.
**bleep** level support.
