i cant use openGL
why i cant use this service
my board
asus P5GC-MX
Intel(R) 82945G Express Chipset Family
windows 7 32bit
- Tags:
 - 5G
You seem to be using Photoshop. I'm not 100% sure but it seems that you have opengl plugin (of Photoshop) missing. Re-installing might help in that case.
OpenGL is supported by the 82945G Express Chipset Family. Please check that your application is installed correctly and has the latest patches and updates. Also, please check to see if you have the latest Intel graphics driver installed. It can be found here:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18223 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18223
i remove adobe and reinstall
but no thing change
i download last version
no thing ghange
i cant use openGL
why why why ?????
thank you
I would recommend contacting Adobe support for help with this issue.
Yes it supports OpenGL 1.4. Please see the following from http://www.intel.com/support/graphics/intel945g/sb/CS-021392.htm http://www.intel.com/support/graphics/intel945g/sb/CS-021392.htm :
The Intel® 82945G Express Chipset Family supports hardware acceleration of OpenGL* applications in 16-bit and 32-bit color depths. OpenGL* 1.4 plus ARB_vertex_buffer and EXT_shadow_funcs extensions and TexEnv shader caching is the latest version currently supported by the Intel® Graphics Media Accelerator Drivers. Drivers that come with Windows* or that are downloaded from Windows* Update typically do not support OpenGL*. For optimal performance of OpenGL applications, install the latest graphics drivers from Intel. Also, exit any running background applications, such as virus scanners, NetMeeting* or any programs that run in the task bar.
I am having problems with Intel 945GM and OpenGL 2.0
I can not get OpenGL 2.0 programs to run...
I am using a HP Mini 110-1100 Netbook with Windows7 Starter
Video Card Vendor: Intel
Renderer: Intel 945GM
OpenGL Version: 1.4.0 - Build 8.14.10.1930
GLU Version: 1.2.2.0 Microsoft Corporation.
I have TRIED to run Intel® Graphics Media Accelerator Driver for Windows* 7(exe) win7_1512754 driver version 15.12.75.4.1930 (8.15.10.1930) and still does not work.
Current pixel format: 6
Pixel Formats supported by this video card
# Type Flags Buf Type Color(R-G-B-A) Z-Depth Stencil Accum(R-G-B-A)
1 ICD 00008024 SGL RGBA 32 (8-8-8-8) 0 0 0(0-0-0-0)
2 ICD 00008025 DBL RGBA 32 (8-8-8-8) 0 0 64(16-16-16-16)
3 ICD 00008024 SGL RGBA 32 (8-8-8-8) 16 0 0(0-0-0-0)
4 ICD 00008025 DBL RGBA 32 (8-8-8-8) 16 0 64(16-16-16-16)
5 ICD 00008024 SGL RGBA 32 (8-8-8-8) 24 8 0(0-0-0-0)
6 ICD 00008025 DBL RGBA 32 (8-8-8-8) 24 8 64(16-16-16-16)
7 GEN 0000807C SGL RGBA 32 (8-8-8-0) 32 8 64(16-16-16-0)
8 GEN 0000807C SGL RGBA 32 (8-8-8-0) 16 8 64(16-16-16-0)
9 GEN 00008465 DBL RGBA 32 (8-8-8-0) 32 8 64(16-16-16-0)
10 GEN 00008465 DBL RGBA 32 (8-8-8-0) 16 8 64(16-16-16-0)
11 GEN 0000807C SGL RGBA 32 (8-8-8-8) 32 8 64(16-16-16-16)
12 GEN 0000807C SGL RGBA 32 (8-8-8-8) 16 8 64(16-16-16-16)
13 GEN 00008465 DBL RGBA 32 (8-8-8-8) 32 8 64(16-16-16-16)
14 GEN 00008465 DBL RGBA 32 (8-8-8-8) 16 8 64(16-16-16-16)
15 GEN 0000807C SGL CI 32 (8-8-8-0) 32 8 0(0-0-0-0)
16 GEN 0000807C SGL CI 32 (8-8-8-0) 16 8 0(0-0-0-0)
17 GEN 00008465 DBL CI 32 (8-8-8-0) 32 8 0(0-0-0-0)
18 GEN 00008465 DBL CI 32 (8-8-8-0) 16 8 0(0-0-0-0)
19 GEN 00000078 SGL RGBA 24 (8-8-8-0) 32 8 64(16-16-16-0)
20 GEN 00000078 SGL RGBA 24 (8-8-8-0) 16 8 64(16-16-16-0)
21 GEN 00000078 SGL RGBA 24 (8-8-8-8) 32 8 64(16-16-16-16)
22 GEN 00000078 SGL RGBA 24 (8-8-8-8) 16 8 64(16-16-16-16)
23 GEN 00000078 SGL CI 24 (8-8-8-0) 32 8 0(0-0-0-0)
24 GEN 00000078 SGL CI 24 (8-8-8-0) 16 8 0(0-0-0-0)
25 GEN 00000078 SGL RGBA 16 (5-5-5-0) 32 8 32(11-11-10-0)
26 GEN 00000078 SGL RGBA 16 (5-5-5-0) 16 8 32(11-11-10-0)
27 GEN 00000078 SGL RGBA 16 (5-5-5-8) 32 8 32(8-8-8-8)
28 GEN 00000078 SGL RGBA 16 (5-5-5-8) 16 8 32(8-8-8-8)
29 GEN 00000078 SGL CI 16 (5-5-5-0) 32 8 0(0-0-0-0)
30 GEN 00000078 SGL CI 16 (5-5-5-0) 16 8 0(0-0-0-0)
31 GEN 00000078 SGL RGBA 8 (3-3-2-0) 32 8 32(11-11-10-0)
32 GEN 00000078 SGL RGBA 8 (3-3-2-0) 16 8 32(11-11-10-0)
33 GEN 00000078 SGL RGBA 8 (3-3-2-8) 32 8 32(8-8-8-8)
34 GEN 00000078 SGL RGBA 8 (3-3-2-8) 16 8 32(8-8-8-8)
35 GEN 00000078 SGL CI 8 (3-3-2-0) 32 8 0(0-0-0-0)
36 GEN 00000078 SGL CI 8 (3-3-2-0) 16 8 0(0-0-0-0)
37 GEN 00000078 SGL RGBA 4 (1-1-1-0) 32 8 16(5-6-5-0)
38 GEN 00000078 SGL RGBA 4 (1-1-1-0) 16 8 16(5-6-5-0)
39 GEN 00000078 SGL RGBA 4 (1-1-1-8) 32 8 16(4-4-4-4)
40 GEN 00000078 SGL RGBA 4 (1-1-1-8) 16 8 16(4-4-4-4)
41 GEN 00000078 SGL CI 4 (1-1-1-0) 32 8 0(0-0-0-0)
42 GEN 00000078 SGL CI 4 (1-1-1-0) 16 8 0(0-0-0-0)
OpenGL extensions found for the current pixel format
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_blend_color
GL_EXT_abgr
GL_EXT_texture3D
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_cull_vertex
GL_SGIS_texture_edge_clamp
GL_SGIS_generate_mipmap
GL_EXT_draw_range_elements
GL_SGIS_texture_lod
GL_EXT_rescale_normal
GL_EXT_packed_pixels
GL_EXT_separate_specular_color
GL_ARB_multitexture
GL_EXT_texture_env_combine
GL_EXT_bgra
GL_EXT_blend_func_separate
GL_EXT_secondary_color
GL_EXT_fog_coord
GL_EXT_texture_env_add
GL_ARB_texture_cube_map
GL_ARB_transpose_matrix
GL_ARB_texture_env_add
GL_IBM_texture_mirrored_repeat
GL_EXT_multi_draw_arrays
GL_NV_blend_square
GL_ARB_texture_compression
GL_3DFX_texture_compression_FXT1
GL_EXT_texture_filter_anisotropic
GL_ARB_texture_border_clamp
GL_ARB_point_parameters
GL_ARB_texture_env_combine
GL_ARB_texture_env_dot3
GL_ARB_texture_env_crossbar
GL_EXT_texture_compression_s3tc
GL_ARB_shadow
GL_ARB_window_pos
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_ARB_vertex_program
GL_ARB_fragment_program
GL_EXT_stencil_two_side
GL_ARB_vertex_buffer_object
GL_EXT_texture_lod_bias
GL_NV_texgen_reflection
GL_ARB_depth_texture
GL_WIN_swap_hint
Did you find the solution? i have the same problem now with CS6
Your IGPs is not supported for OpenGL acceleration in Adobe products, because they require OpenGL version 2.0 support, look at http://helpx.adobe.com/photoshop/kb/gpu-opengl-support-photoshop-cs4.html Photoshop Help | GPU, OpenGL support | Photoshop CS4, CS5 . You have no ways to force them work - old IGPs lack HW capabilities required, especially true VS&PS shader model support. Practically, only HD graphics line IGPs have both enough technological level and 'muscles' for such tasks, HD3000/4000 even with HW support needed have very bad driver support and too little raw GPU powers.
